Module Inbox (webmail)
Revision as of 20:42, 20 November 2026 by John Botella (talk | contribs) (creation of page)
Module name Inbox
Editor / Editeur THERSANE (techsane.fr) - inbox.techsane.fr
Prerequisites / Prérequis PHP 7.4+, an IMAP mail server. On Dolibarr 23 only: module backportdolcontext.
Dolibarr min version: 23.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2026-11-20
Note / Nota Free external module, GPL v3 licence. Module number 141930.
Description
Inbox is a webmail built into Dolibarr ERP CRM, designed for teams. It connects over IMAP and SMTP to the mailboxes you already have, so there is no mail server to change, and it shows each email next to the matching third party, contact and documents of Dolibarr.
  • Shared and personal mailboxes, with four access levels per mailbox: read, send, handle, manage
  • Sender recognised among third parties and contacts; a third party or a commercial proposal can be created from an email
  • Assignment of an email to a colleague, internal notes on emails
  • Shared tags, rules applied on the mail server (Sieve) and out of office replies
  • Rich text editor, signatures per identity, Dolibarr email templates, scheduled sending
  • Search with filters (tag, attachment, period) and search in the text of emails
  • Protection against impersonation: lookalike domains and misleading display names are flagged, recognised domains of partners, reminder to check any change of bank details by phone
  • Remote images and trackers blocked by default, list of blocked senders shared by all mailboxes
  • Installable web application for phones, light and dark theme
  • Interface in English, French, German, Italian and Spanish
Features that call an external service (sender pictures, artificial intelligence, reputation lists) are disabled by default.
Prerequisites
  • Dolibarr 23.0 or newer
  • PHP 7.4 or newer. The PHP extension intl is advised (domain names with accents).
  • A mail server reachable over IMAP and SMTP
  • On Dolibarr 23 only: the free module backportdolcontext. From Dolibarr 24, nothing else is needed.
Download the file module_inbox-X.Y.Z.zip of the latest release: GitHub releases.
From the application
Manually
unzip modulefile.zip
Then, on the setup page of the module:
  1. Add a mailbox: address, server and password. Inbox tests the connection and finds the special folders (sent, drafts, trash...).
  2. Give access: choose for each mailbox which users or groups can read, send, handle or manage it.
Links
