List of modules id
Revision as of 08:19, 20 November 2026 by Jacobo (talk | contribs)
This page list all reserved modules numbers / ID.
If you build or want to build your own modules, you should take an ID range here. Please pick range into existing holes first.
ID 0 - 94999
This range is reserved for Dolibarr's internal core modules, so all modules available into the standard distribution at https://github.com/Dolibarr/dolibarr
ID 95000 - 99999
This range is reserved for Dolibarr's community modules with sources hosted into the github repository: https://github.com/Dolibarr/dolibarr-community-modules
ID 100000 - 499999
Reserved area for editors in need for an ID range. You can edit this page to add your own range (take a range of 20 numbers only the first time, ask us for more)
Warning.png If you reserve more than 10 at once, we may automatically change your reservation range without information and you may experience conflicts with other modules in a future, so please follow the rules!
DO NOT ADD RECORD HERE, PLEASE FILL HOLES FIRST !!!! ...
ID > 500000
This range can't be reserved. It is a common range. If you don't plan to distribute your module, you can use an ID in this range with no need to reserve it.
If you don't already have reserved ids and need some, please don't use hazardous number and use a number higher than 500000, but it is better to ask a wiki account, and reserve your own range by editing the 100000 - 499999 range (10 ids at once).
