Application Android - Mobilid
Revision as of 19:08, 18 November 2026 by Fappels (talk | contribs) (→‎Features: update description)
Module name Mobilid
Editor / Editeur Z-Application - www.mobilid.eu
Download or buy page / Page achat ou téléchargement External module - www.dolistore.com - Google Play
Last update date / Date mise à jour fiche / Fecha última actualización 2026-11-18
Android barcode scanner app for Dolibarr warehouse management. Scan barcodes for inventory and stock management, order picking, goods receiving, stock transfers and order creation. Works on Android barcode terminals, PDAs and phones. Fewer picking errors, faster warehouse work, real-time stock.
When installed in custom folder you will have to choose the 'dolibarr custom' connector in the Mobilid app main settings.
You can read the full documentation at https://docs.z-application.com
