Module DMS Advanced Text Editor
Revision as of 10:13, 15 November 2026 by Dolibarr-module-solution (talk | contribs) (New page: DMS Advanced Text Editor module (DMS — Dolibarr Module Solution))
Editor DMS — Dolibarr Module Solution (dolibarrmodulesolution.com)
Module ID 194317
Version 1.0.1
Dolibarr 18 to 24
PHP 7.4 or later
Where to get it Ask DMS by email (DoliStore publication in progress)
Support support@dolibarrmodulesolution.com
Presentation and videos dolibarrmodulesolution.com
Dolibarr's text boxes become a block editor, as simple as a word processor, for your notes, descriptions, emails and signatures.
A customer note, a product description, an email template, a signature: in Dolibarr, everything starts with a text box. Formatting that text quickly becomes tedious.
DMS Advanced Text Editor replaces these boxes with a block editor. You write as you would in a word processor, with headings, lists, tables and images, without losing any of the text you already have.
What the module gives you
  • Paragraphs, headings, lists, checklists, quotes, callouts and tables, created straight from the keyboard or with the "+" button.
  • Images and files added within a text; an image placed on a record follows the permissions of that record.
  • Values from the record, such as the customer, the project or the sales representative, inserted into a text and replaced with the real value when an email is sent.
  • Your existing text opens as editable blocks; anything the editor could not rewrite identically is kept as it is in a protected block.
  • Text looks the same everywhere: while you write, once saved, in a PDF and in an email.
  • Images in an email travel with it, so your recipient sees them without logging in.
Day to day
  • On a customer record, you write a note with a heading, a list and an image, just as in a word processor.
  • In a quote email, you insert the customer's name: it shows as a tag while you write and the real value goes out when you send.
  • On the module's setup page, the administrator chooses which groups of fields get the editor: descriptions, document lines, notes, emails, user signatures, tickets.
Frequently asked questions
What happens to the text we have already entered?
It opens as editable blocks. A passage the editor could not rewrite identically is kept as it is, and a notice says so. Text that nobody edits stays exactly as it was.
What happens if we disable the module?
Your text stays intact: it is saved in Dolibarr's standard format. The module also puts back the settings of the original editor that it had taken over when it was enabled.
Do we need any other module?
No, no other module is required. When enabled, the module switches off Dolibarr's original text editor, because a field must never carry two editors. The Websites module stays enabled.
Videos
Home → Setup → Modules → "Deploy/install external app/module", upload the zip file and enable the module. Nothing in Dolibarr itself is modified, so Dolibarr updates keep working.
Support
Questions before installing, or a problem with the module: write to support@dolibarrmodulesolution.com. The module page, with its videos, is on dolibarrmodulesolution.com.
