Module DoliSCAN
Revision as of 10:51, 13 November 2026 by Eric.seigne (talk | contribs) (DoliSCAN 2.2.30)
Information
Module name DoliSCAN
Editor / Editeur CAP-REL - doliscan.fr
Prerequisites / Prérequis Suppliers, Third parties, Banks, Expense reports, Invoices, DMS (ECM) and Scheduled jobs modules; Projects and Multicompany optional
Last update date / Date mise à jour fiche / Fecha última actualización 2026-11-13
Note / Nota Expense reports from a smartphone: employees photograph their receipts with the DoliSCAN app, and Dolibarr receives the expense reports and supplier invoices, receipts attached.
Typing expense reports is repetitive work. With DoliSCAN, employees photograph their receipts on their smartphone and pick the expense type; the module does the rest in Dolibarr.
At a glance
  • Who it is for: companies whose employees spend money on the road (meals, fuel, tolls, hotels, train), and the accountants who process those expenses.
  • What it does: it imports the expenses entered in the DoliSCAN smartphone app into Dolibarr, once a day: an expense paid with a personal means of payment becomes an expense report line, an expense paid with a company means of payment becomes a supplier invoice. The receipts are downloaded and attached.
  • What it needs: an account on a DoliSCAN server, the production server doliscan.fr (billed per active account) or a self-hosted one.
Feature list
  • Automatic synchronization - a daily scheduled job imports the expenses of every active account, with a manual synchronization per account or for everybody.
  • Personal or professional expenses - the means of payment chosen in the app decides the document: expense report line to reimburse, or supplier invoice, optionally paid automatically.
  • Receipts - PDF and photos are downloaded from the DoliSCAN server and attached to the Dolibarr documents; a receipt not ready yet on the server is fetched again at the next synchronizations.
  • One account per employee - each employee has their own DoliSCAN account linked to their Dolibarr user, and only sees their own expenses; wider access (accounting, management) goes through Dolibarr permissions.
  • Projects - Dolibarr projects are sent to the app so that an expense can be assigned to a project.
  • French fuel tax rules - partial VAT recovery on fuel, 80 % or 100 % depending on the vehicle type.
  • Meal caps - configurable cap on meal expenses per user group.
  • Multicompany - compatible with the Multicompany module, with a mapping of the accounts per entity.
  • Diagnostics - a maintenance page checks the scheduled job, the clock, the user permissions and the data consistency, and fixes what it can.
  • Seven languages - English, French, German, Spanish, Italian, Dutch and Brazilian Portuguese.
Screenshots
Links
Requirements
Item Version or condition
Dolibarr 18.0 or higher
PHP 7.4 or higher
DoliSCAN server an account on doliscan.fr or on a self-hosted server
Rights an administrator account to install, enable and set up the module
Dolibarr module Used for
Suppliers supplier invoices of the professional expenses
Third parties suppliers linked to the expense types
Banks bank account of each professional means of payment
Expense reports expense report lines of the personal expenses
Invoices invoicing
DMS (ECM) storage of the receipts
Scheduled jobs daily synchronization
Projects (optional) assignment of an expense to a project
Multicompany (optional) one DoliSCAN setup per entity
Upgrade
  1. Install the new version through Home > Setup > Modules/Applications > Deploy/install external app/module.
  2. Disable then enable the module again: enabling applies the database upgrades and registers the new permissions.
The accounts, the settings and the imported expense reports are kept.
Uninstall
Disable the module from Home > Setup > Modules/Applications. The DoliSCAN data (linked accounts, synchronized expense reports) stays in the database: enabling the module again resumes the synchronization where it stopped.
Before setting up the module, complete the Company/Organization card (name, address, email, phone, website, company identifiers, managers): the DoliSCAN server checks it when the administrator account is created.
The setup is in Home > Setup > Modules > DoliSCAN, in numbered tabs to go through in order:
Tab Purpose
1. Server choose the DoliSCAN server: production, test or self-hosted
2. Administrator create or link the administrator account, check the connection, choose the import start date
3. Supplier links Dolibarr supplier of each professional expense type
4. Expense types Dolibarr expense type of each personal expense type
5. Means of payment bank account and payment mode of each professional means of payment
6. Miscellaneous automations: account creation, payment, validation and approval, projects
7. Fuel partial VAT recovery depending on the vehicle type
8. Special rules meal caps per user group
Multicompany accounts of employees working for several companies
Tabs 3, 4 and 5 download their lists from the DoliSCAN server: set up the server and the administrator account first. Use a generic administrator account (for example admin@example.com), not a personal one: an administrator account cannot have expense reports.
Permissions
The permissions are granted from Home > Users & Groups, Permissions tab, DoliSCAN section.
Permission Purpose
Read / create / delete my own DoliSCAN account an employee manages their own account (each active account is billed by the server)
Read / delete my own DoliSCAN expense reports an employee sees their own imported expense reports
Validate, cancel or reset to draft my own DoliSCAN expense reports status changes made by hand (the automatic import does not need it)
Download the DoliSCAN expense reports of other users accounting or administrator, to process everybody's expenses
Read / create / delete all DoliSCAN accounts administration of the employee accounts
The module adds a DoliSCAN application entry in the HRM menu.
Home page
The home page shows the number of accounts, the expense reports waiting and synchronized, and the dates of the last synchronization and of the last import. Three buttons: Synchronize the projects, Synchronize the missing receipts and Check / fix the VAT errors.
Synchronization
The scheduled job runs once a day: it sends the projects to the server, synchronizes the expense reports of every active account, then downloads the missing receipts. The server accepts one synchronization per 23 hours; schedule the job after 4 pm so that the PDF of the day are ready. A manual synchronization is available from the All accounts page (for everybody or for one account) and from the My account page.
Projects
When the Projects module is enabled, each validated project gets a DoliSCAN code field. The code shows in the smartphone app so that an expense can be assigned to the project. Closed projects can be hidden.
The full user guide is in the documentation.
FAQ
The synchronization does not start.
Check that the scheduled job is enabled in Home > Setup > Scheduled jobs, that no synchronization ran in the last 23 hours, and test the connection from the Server tab of the setup.
Supplier invoices are not created.
They are created only for expenses paid with a professional means of payment. Check that each professional expense type is linked to a Dolibarr supplier in the Supplier links tab.
A receipt is missing, or a PDF shows a "document unavailable" image.
Open the diagnostics page of the module: section 9 lists and removes the placeholder images. Then click Synchronize the missing receipts on the home page.
How does the partial VAT recovery on fuel work?
With the French tax rules enabled in the Fuel tab, a utility vehicle keeps 100 % of the VAT; a passenger car gets a line with 80 % of the VAT of the receipt and a complement line at 0 % for the part that cannot be recovered.
All questions: documentation FAQ.
Developments and improvements can be suggested to the project maintainer by email (see the headers of the source files) or through the support form.
