Module AIRA BI
Revision as of 16:33, 12 November 2026 by Weglob (talk | contribs) (Version 1.4.3)
Module name AIRA BI
Editor / Editeur Weglob - https://weglob.com
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/product.php?id=2841
Prerequisites / Prérequis Dolibarr 19.0+, PHP 8.0+, an AI provider API key
Last update date / Date mise à jour fiche / Fecha última actualización 2026-11-12
Note / Nota Module ID 500100
Module AIRA BI
Name Value
Publisher Weglob
Status Stable
Version 1.4.3
Module ID 500100
Dolibarr compatibility 19.0 and later
License GPL v3 or later
Languages English, French
Description
AIRA BI is an AI assistant built into Dolibarr. Users ask questions about their ERP data in plain language and get the answer as text, a table or a chart.
Example questions:
  • sales by month over 6 months
  • top 10 customers by revenue
  • unpaid invoices by customer
  • bank account balances
  • projects by status
The engine follows a controlled flow: question → schema context → AI plan → validation → read-only SQL → display in the chat. It is a Dolibarr assistant, not a general-purpose chatbot.
  • Answers as text, table or chart depending on the question.
  • Conversation memory: follow-up questions, refine a filter, ask for another view.
  • Conversations saved per user and per entity, reopen or delete them from the sidebar.
  • Links to native reports (customreports.php) when the result matches a Dolibarr report.
  • Starter suggestions on the welcome screen, shown only when the user has the required rights.
  • Help on Dolibarr usage ("how do I create an invoice?") without reading the database.
  • Choice of AI provider: OpenRouter (hundreds of models, some free), OpenAI, Google Gemini, NVIDIA.
  • Clear error messages (provider, model, technical error) when the AI API fails.
Security
Every query goes through a SQL guard:
  • SELECT only, a single statement, no comments or variables.
  • No write queries, no export (INTO OUTFILE), no system schemas.
  • Whitelist of business tables: each table needs the matching Dolibarr module and the user's permission (e.g. invoices require "Read invoices").
  • Sensitive columns are blocked (passwords, API keys, tokens).
  • entity filter enforced (multi-company safe).
  • Row count and execution time are capped.
  • Runs in a read-only transaction, or with a read-only MySQL user (recommended).
API keys and the read-only MySQL password are encrypted in the database and never displayed again.
Privacy
Sent to the AI provider: the question, the conversation history and the description of the allowed tables. Query results are not sent. Free offers (OpenRouter :free models, Gemini free tier, NVIDIA trial credits) may log prompts: prefer a paid offer for sensitive data.
Screenshots
  1. Buy and download the module zip from DoliStore.
  2. Go to Home > Setup > Modules/Applications > Deploy/install external module and upload the zip.
  3. Or unzip it manually into htdocs/custom/ so you get htdocs/custom/aichat.
  1. Enable the AIRA BI module.
  2. Open the module setup page.
  3. Choose the provider: OpenRouter, OpenAI, Google Gemini or NVIDIA.
  4. Enter the API key (a "Get a key" button opens the provider page).
  5. Choose the model. For OpenRouter, the list comes from the live catalog with prices and context size; a warning is shown if the configured model was removed.
  6. Save.
  7. Optional but recommended: create a read-only MySQL user and enter it in the setup:
CREATE USER 'dolibarr_ro'@'localhost' IDENTIFIED BY 'password';
GRANT SELECT ON dolibarr.* TO 'dolibarr_ro'@'localhost';
  1. Optional: enable the Dolibarr BI / reports feature to get customreports links in the chat.
The Dolibarr server must reach the provider API over HTTPS (PHP curl.cainfo set with root certificates).
FAQ
The assistant answers with an AI error
Check the API key, the quota and that the model is still available. The message shows the provider and model in use.
"No data found"
No Dolibarr record matches. Change the period or the filter.
A user does not see some suggestions or gets a refusal
The user lacks the Dolibarr permission on the module behind that data (invoices, orders, bank...). This is intended.
Can it modify my data?
No. Only read-only SELECT queries are allowed.
Support
