Module Bloxera Buchhaltungs-Export DATEV-Format
Information
| Module name | Accounting Export DATEV-Format |
| Editor / Editeur | Bloxera GmbH - https://www.bloxera.com |
| Download or buy page / Page achat ou téléchargement | External module - tbd. |
| Status / Statut / Estado | Experimental |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2026-11-1 |
| Note / Nota | Find a detailed description of the module and its settings here: https://www.dolicenter.com/accounting-export-datev.php |
Dolibarr has many built in import formats for double entry accounting. This modules adds an additional export format (DATEV-format) which is very common in Germany.
More info
Module description (in German): https://www.dolicenter.com/accounting-export-datev.php
