Module MegaNotes
Revision as of 09:06, 28 October 2026 by Eric.seigne (talk | contribs) (MegaNotes 1.0.4)
Information
Module name MegaNotes
Editor / Editeur CAP-REL - cap-rel.fr
Prerequisites / Prérequis None for the web interface; SmartAuth module for the mobile application
Last update date / Date mise à jour fiche / Fecha última actualización 2026-10-28
Note / Nota Enriched note taking inside Dolibarr: quick entry with sigils, links to third parties and Dolibarr objects, keywords, statuses, dashboard and mobile application.
MegaNotes brings into Dolibarr what is said on the phone, on the field or in a meeting, the moment you write it down. Each note (called a "need" in the module) is linked to the third parties and Dolibarr objects it is about, sorted by category, followed by status, and found again by keyword.
At a glance
  • Who it is for: sales teams, support and field teams who take notes along their exchanges with customers.
  • What the module does: it records notes in Markdown, links them to third parties and Dolibarr objects through sigil entry, extracts their keywords and shows the list, the recurring topics and the statistics.
  • What it does not do: it creates no Dolibarr object from a note (no proposal, order or intervention) and declares no scheduled job.
Feature list
  • Quick entry - Markdown editor (EasyMDE), submit with Ctrl+Enter, category picked or created while typing, public or private note.
  • Sigils - $ links a third party, # adds a tag, & links a Dolibarr object: project, task, proposal, order, invoice, intervention, contract, product or service, depending on the enabled modules.
  • Statuses - New, In progress, Done, Dropped, changed straight from the list.
  • Keywords - extracted automatically from the text on a quick entry or from the mobile application; the 50 most frequent are shown, words found in three notes or more are flagged as recurring.
  • Statistics - breakdown by status, ten most used categories, number of notes created per month over the last twelve months.
  • Card of a note - extra fields, contacts, notes, attached documents, events, sending by email, cloning.
  • Quick access - optional icon in the top bar of Dolibarr.
  • Mobile application - web application (PWA) to read and write notes from a phone, change their status and archive them.
Screenshots
Links
Requirements
Item Version or condition
Dolibarr 18.0 or above
PHP 7.4 or above
Rights an administrator account to install, enable and set up the module
Mobile application the SmartAuth module enabled, and a public HTTPS address whose root is the pwa directory of the module (virtual host or DoliProxy subscription)
The web interface needs no other module. The & sigil only offers the objects of the enabled Dolibarr modules.
Upgrade
  1. Install the new version through Home > Setup > Modules/Applications > Deploy/install external app/module.
  2. Disable then enable the module again: enabling it applies the database upgrades. Existing notes are kept.
Uninstall
Disable the module from Home > Setup > Modules/Applications. The data is not deleted.
The setup lives in Home > Setup > Modules > MegaNotes and is restricted to administrators. It has three tabs: Settings, Extra fields and About.
Settings
Setting Purpose Default value
Add the MegaNotes icon in the top right menu shows a shortcut icon to the home page of the module in the top bar no
Extra fields
The Extra fields tab adds your own fields to the notes; they show in the form and on the card of a note.
Scheduled jobs
The module declares no scheduled job.
Permissions
Three permissions, granted by an administrator from Home > Users & Groups, Permissions tab:
  • Read: card of a note, its tabs and the advanced list;
  • Create/Update: creation through the standard form, update and cloning;
  • Delete: deletion of a note.
The MegaNotes menu entries are shown to every user.
Once enabled, a Mega Notes entry shows in the left menu of Commercial and of Documents (DMS). The home page gathers three views, a list, the keywords and the statistics, with filters by text, category, status, visibility and period. The labels of the home page and of the quick entry are in French in every language for now.
Quick entry
The + Nouveau besoin button opens the quick entry. Type for instance 2T of gravel for $Dupont, #urgent delivery on &PROJ-2024-001: the note is linked to the third party, gets the tag and is attached to the project.
Mobile application
The application signs in with the usual Dolibarr credentials. It shows counters and the latest notes, the list of notes, the creation of a note with the same sigil entry, and the status change or archiving from the card. A note created from the phone is private; in the application, a private note is only visible to its author.
Every screen is described in the user guide and the application in its own guide.
FAQ
The MegaNotes menu does not show.
Check that the module is enabled and look in the left menu of Commercial or Documents (DMS): these main menus only exist when a module of their area is enabled.
The sigils do not react.
They work on the quick entry page, not in the standard form of the card.
The mobile application does not sign in.
Enable the SmartAuth module and serve the pwa directory of the module at the root of an HTTPS address.
All the questions: FAQ of the documentation.
Developments and improvements can be suggested to the project manager by email (see the headers of the source files) or through the support form.
