Module CapAgenda
Revision as of 10:12, 27 October 2026 by Eric.seigne (talk | contribs) (CapAgenda 1.0.0)
Information
Module name Capagenda
Editor / Editeur CAP-REL - www.cap-rel.fr
Prerequisites / Prérequis Agenda module
Last update date / Date mise à jour fiche / Fecha última actualización 2026-10-27
Note / Nota Another view for your Dolibarr agenda: a single modern page with day, week, month, list and per-colleague planning views, drag and drop and remembered filters, without changing your events.
The native Dolibarr agenda does the job, but moving an appointment, switching views or finding a colleague's events takes many clicks. CapAgenda replaces it with a single, fast and readable page, in the spirit of the online calendars everybody knows.
At a glance
  • For whom: any team that organises its appointments, calls, interventions and meetings in Dolibarr, from sales people to technicians and assistants.
  • What the module does: it shows and edits the events of the Agenda module in a modern interface, with the views, filters and shortcuts of an online calendar.
  • What it does not do: it creates no table and copies no event; reminders, triggers and the modules hooked on the agenda keep working. It calls no external service: the calendar library ships inside the module.
Feature list
  • One page, every view - day, week, month, list and per-colleague planning; the last view used is remembered for each user.
  • Full width - the Dolibarr left menu is hidden on the agenda (option on by default), a foldable side panel gathers the Create button, a mini month and the filters.
  • Drag and drop - move an appointment, change its duration from its bottom edge, reassign it by dragging it from one planning line to another.
  • Quick creation - select a time slot, search the third party and the project by name or reference, then go on to the native card for notes, reminders and contacts.
  • Colleagues as colored boxes - each colleague has a box in the color of their events, with the Me, My team and All shortcuts.
  • Soft colors - events in pastel tints, by colleague or by event type, taken from the user cards and the event type dictionary.
  • Remembered filters - calendars (my events, the others', leaves, birthdays, iCal calendars, other modules), types, status, third party, project and resource.
  • Statuses and undo - status 0, 50 or 100 % from the detail panel, undo of the last change for a few seconds, protection against simultaneous changes.
  • Keyboard shortcuts - navigation, view switching, creation, filters and undo from the keyboard.
  • Dark mode, mobile and printing - the theme follows Dolibarr, the display fits phones, printing drops the toolbars.
  • Native agenda takeover - as an option, the native calendar pages redirect to CapAgenda; the native list view stays available.
  • Seven languages - French, English, German, Spanish, Italian, Dutch and Portuguese (Brazil).
Screenshots
Links
Requirements
Item Version or condition
Dolibarr 18.0 or later
PHP 7.4 or later
Dolibarr module Agenda enabled
Rights an administrator account to install, enable and set up the module
The Leaves, Projects and Resources modules are optional: when they are enabled, their data shows in the filters and in the agenda.
Upgrade
  1. Install the new version through Home > Setup > Modules/Applications > Deploy/install external module.
  2. Disable then enable the module again: the activation records the new permissions and the new options.
Events are not touched, and the preferences of every user are kept.
Uninstall
Disable the module from Home > Setup > Modules/Applications. The module stores no event: the native agenda is exactly as it was.
The setup page is in Home > Setup > Modules > Modern agenda.
Setting Purpose Default
Redirect the native agenda to the modern agenda the native calendar pages (month, week, day, per user) open CapAgenda; the native list view is never redirected no
Hide the Dolibarr left menu on the agenda the agenda takes the whole width of the screen; the menu stays on the other pages yes
Default view view offered to a user who did not choose yet week
Default event color color of the owner colleague or of the event type colleague
Default slot duration 15, 30 or 60 minutes 30 minutes
Leaves and birthdays colors colors of these two calendars blue grey and soft orange
Maximum number of events per request beyond it, the period is truncated and a banner asks to narrow the filters 5000
Undo notification duration how long the undo stays offered after a change 8 seconds
Working hours and days, the first day of the week and the iCal calendars are set as usual on the native Agenda module setup page: CapAgenda uses them.
Permissions
The module adds a single permission, Use the modern agenda, granted on activation to every user who can already read the agenda. Beyond that, CapAgenda applies exactly the rights of the Agenda module: read, create and delete one's own events or everybody's.
Once enabled, the Modern agenda entry shows in the Agenda menu.
Moving around
The three bars button shows or hides the side panel. Today and the arrows change the period, the mini month opens any day, and the menu at the top right switches the view.
Creating and editing
Select a time slot with the mouse to open the quick creation, or use the Create button. Drag an event to move it, pull its bottom edge to change its duration. A notification offers to undo each change for a few seconds.
Filtering
Check or uncheck the colleagues in the side panel; the other filters (group, color, types, status, third party, project, resource) sit under More filters. The choices are remembered for each user.
Every view and every shortcut is described in the user guide.
FAQ
Were my events converted or copied?
No. The module creates no table: it shows and edits the events of the Agenda module, through the same classes as the native card.
Do reminders and notifications keep working?
Yes: every write goes through the Dolibarr core, triggers and reminders fire as from the event card.
A colleague changed an event while I was moving it.
The move is refused, a message explains the conflict and the view refreshes: nobody overwrites someone else's work without knowing it.
The planning view does not show every user.
The planning lines follow the checked colleagues and your rights: without the right to read every event, you only see your own line.
How do I go back to the native agenda?
Add capagenda_native=1 to the address of the native page, uncheck the redirect option, or use the Classic agenda entry of the three dots menu.
All the questions: documentation FAQ.
Developments and improvements can be suggested to the project lead by email (see the headers of the source files) or through the support form.
