Module UpInvoice: Automatic Supplier Invoices
Revision as of 11:02, 16 October 2026 by Tengaweb (talk | contribs) (Fecha de última actualización / Last update date: 2026-10-16)
Information
Module name UpInvoice
Editor David Motilla / UpInvoice.eu
License GPL-v3
Download Dolistore
Status Stable
Requirements Dolibarr 14.0.0 – 24, UpInvoice API key, Supplier and Supplier Invoices modules enabled
Last update 2026-10-16
UpInvoice lets you capture supplier invoices (PDF or images), extract their data automatically with the UpInvoice AI API, validate the supplier and register the invoice in Dolibarr in a three-step process.
Main features:
  • Multiple file upload with duplicate detection
  • Automatic data extraction via the UpInvoice API
  • Advanced supplier search and creation system
  • Data validation with automatic calculations
  • Supplier invoice creation with or without validation
Automatic email intake
The module can collect incoming invoices directly from an email mailbox, through the integration with Dolibarr's EmailCollector module. From the setup page you can create a preconfigured collector with one click and enable automatic AI processing (via cron). Import rules (sender, subject, filename pattern) and a sender blacklist are available, plus a live mailbox tab to import attachments manually.
  1. Install the module from Dolistore or upload it manually
  2. Go to Setup > Modules and activate the UpInvoice module
In the module configuration, enter the API URL and your UpInvoice API key (available at upinvoice.eu). A subscription to the service is required; some free invoices are included for testing.
More information
