Module Two-Factor Authentication (2FA)
Revision as of 22:09, 14 October 2026 by Theopequiii (talk | contribs) (Version 6.0.4: Google Authenticator fix, verified on Dolibarr 16 to 24)
Editor Theo Pequignot (theopequignot.fr)
Module ID 194155
Version 6.0.4
Dolibarr 16 to 24
Where to get it DoliStore
Support contact@theopequignot.fr
Presentation and support modules.theopequignot.fr
One stolen, guessed or reused password is enough to get into your Dolibarr, and with it into your customers, invoices and bank accounts. This module adds a second factor to the login: even with the right password, nobody gets in without the user's phone, key or fingerprint.
Three methods, each user picks
  • TOTP app: 6-digit code renewed every 30 seconds. Works with Google Authenticator, Microsoft Authenticator, Authy, 1Password, Bitwarden, Aegis, FreeOTP. The QR code is generated on your server, no third-party service.
  • WebAuthn / FIDO2: security keys (YubiKey…) and built-in biometrics (Windows Hello, Touch ID, Face ID). One touch and you're in.
  • Backup codes: 10 single-use codes, stored as bcrypt hashes, so a lost phone never locks anyone out.
Several devices per account
  • A user can register a phone, a security key and a laptop, and name each one.
  • Users add, rename or revoke their own devices from the Security tab of their user card.
Hardened by design
  • TOTP secrets encrypted at rest (AES-256-CBC).
  • Lockout after a configurable number of failures (5 by default).
  • Anti-replay: an accepted code cannot be used twice.
  • Audit log of every attempt: date, IP address, method, device, result.
  • CSRF protection on every form and strict HTTP headers on the login pages.
For the administrator
  • 2FA optional or mandatory for everyone, with one checkbox.
  • Users are prompted to set up 2FA at their next login.
  • Dashboard: adoption rate, last 24 h activity, blocked IP addresses.
  • Overview of all users, reset of an account's 2FA, forced re-enrollment.
  • Responsive login pages that stay readable whatever the Dolibarr theme.
Home → Setup → Modules → "Deploy/install external app/module", upload the zip and enable the module. Tables are created automatically.
Upgrading from a previous version: replace the files, then disable and re-enable the module (Setup → Modules). Settings, data and user permissions are kept.
Compatibility
  • Dolibarr 16 to 24 (verified on 16, 17, 18, 19, 20, 21, 22, 23 and 24).
  • PHP 7.4 to 8.4, MySQL / MariaDB, OpenSSL extension.
  • HTTPS required for WebAuthn / FIDO2 (a browser requirement).
  • English and French included. Email support and updates for 2 years.
Screenshots
Versions
  • 6.0.4 (14 October 2026): Google Authenticator rejected the QR code while other apps accepted it. The TOTP key is now 32 characters long (160 bits) instead of 20, a length Google Authenticator refused. Devices already registered keep working. When a code is right but the phone or server clock is off, the page now shows the drift instead of a plain "invalid code". Bigger QR code and clearer scan instructions.
  • 6.0.3 (3 October 2026): security fix, update recommended on Dolibarr 16 to 18. On these versions the second factor was not asked: the check relied on a Dolibarr hook that only exists from version 19. It now goes through a hook present in every version and called on every request. On every version, document downloads and exports also require the verification.
  • 6.0.2 (2 October 2026): administration page fixed, interface translated into French and English.
Support
Questions before buying, installation or update issues: write to contact@theopequignot.fr. I am the developer of this module and I answer myself. Support and updates are included for 2 years with the DoliStore purchase. The full presentation of the module, its screenshots, frequently asked questions and the support form are on modules.theopequignot.fr. Purchases are made on the DoliStore.
