Module TCMB Kur
All TCMB currencies Buying · Selling · Banknote Correct dating Archive backfill Cross rates Free · GPLv3
Overview
TCMB Exchange Rates is a free external module for Dolibarr ERP/CRM that imports the daily indicative exchange rate bulletin of the Central Bank of the Republic of Türkiye (TCMB) into the rate table of the Dolibarr Multicurrency module.
It writes through Dolibarr core classes (no direct SQL on core tables) and does not modify any core file.
Publisher and support
| Item | Information |
| Publisher | M. Burak Şentürk |
| Website | https://buraksenturk.net |
| Support | https://github.com/mbrksntrk/dolibarr-tcmb-kur/issues |
| Source code | https://github.com/mbrksntrk/dolibarr-tcmb-kur |
Module information
| Information | Detail |
| Module name | TCMB Exchange Rates (tcmbkur)
| Module number | 194093 |
| Main use | Daily TCMB exchange rates in Dolibarr multicurrency |
| Type | External Dolibarr module |
| Family | Financial |
| Documented version | 1.0.0 |
| Dolibarr compatibility | Dolibarr 20.0 or higher (developed and tested on 24.0) |
| PHP compatibility | PHP 8.1 or higher, with curl, simplexml
| Required modules | Multicurrency |
| Dolibarr core modification | No |
| License | GNU GPL v3 or later (with an author attribution term) |
| Price | Free |
| Available languages | Turkish, English |
Official links
- DoliStore: TCMB Exchange Rates
- Source code and releases: GitHub
- Detailed documentation (Turkish): GitHub wiki
Main features
- Any currency of the bulletin (default USD, EUR, GBP); missing currencies are created in Dolibarr.
- Rate type: forex buying (Turkish tax-law practice), forex selling, banknote buying/selling, or buying/selling average.
- Correct dating: the bulletin of day D is stored for the next business day (can be disabled); weekends skipped. Works with
MULTICURRENCY_USE_RATE_ON_DOCUMENT_DATE. - Backfill: past bulletins are fetched from the TCMB archive to fill missing days; holidays fall back to the last published bulletin.
- Non-TRY main currency: cross rates are computed when the company works in EUR, USD…
- Both Dolibarr directions written correctly (
rateandrate_direct); 100-unit rates (e.g. JPY) normalised per unit. - Daily scheduled job, no duplicates for the same date.
- Setup page with the current bulletin, Import now, Backfill and a run log (
llx_tcmbkur_log). - MCP tools for the Dolibarr 24 AI module:
tcmb_rates,tcmb_sync.
From Home → Setup → Modules → TCMB Exchange Rates: currencies, rate type, date behaviour, backfill days. Then in Home → Setup → Scheduled jobs, set TcmbKurDailySync after 16:00 (Türkiye time) and disable the core "update all currency rates" job so the two sources do not overlap.
User permissions
- Read TCMB rates
- Update TCMB rates
- Download
module_tcmbkur-x.y.z.zipfrom DoliStore or GitHub Releases. - Home → Setup → Modules → Deploy/install external app/module, or unzip into
htdocs/custom/. - Enable the Multicurrency module, then TCMB Exchange Rates.
- Open the setup page and use Backfill to load the last 30 days.
TCMB Exchange Rates keeps Dolibarr multicurrency rates in line with the official Central Bank of Türkiye bulletin — correct rate type, correct date, history backfill and cross rates — using only standard Dolibarr classes.
