Module Fluide EN
Revision as of 15:15, 23 September 2026 by Altaxia (talk | contribs) (Create page for the Fluide module)
Fluide - Reading comfort for Dolibarr lists
Dolibarr lists are dense and long. Fluide fixes the things that make them tiring to read, without changing what they contain.
  • Editor: Altaxia (www.altaxia.fr)
  • Licence: GPL v3 or later
  • Compatibility: Dolibarr 21.0 to 25.0
  • Download: DoliStore
  • Support: hello@altaxia.fr
  • Frozen list header: column titles stay visible while you scroll
  • Column widths adjustable by dragging, remembered per list and per user
  • Display density setting, to fit more rows on screen without zooming out
  • Return to reading position when coming back from a card to its list
  • Contextual side menu and a mass-action bar that stays reachable
What it does not do
Fluide changes no data and no business rule. Column preferences are stored per user, so two people can read the same list their own way.
Deploy the module folder in htdocs/custom/ or directly in htdocs/, then enable it in Setup > Modules. Settings are on the module configuration page.
