Module DueCustomers
Revision as of 09:28, 22 August 2026 by Lbouquet (talk | contribs) (Version numbers update)
Module name DueCustomers
Editor / Editeur Joliciel - [www.joliciel.fr]
Last update date / Date mise à jour fiche / Fecha última actualización 2026-08-22
Presentation
This documentation is about the external module "Due Customers".
It generates a PDF table of the rest due by customers (as of the current date) :
Publisher: Joliciel
Module Version: 1.4.11
Compatibility: Dolibarr 8.x - 24.x
Contact: dolibarr@joliciel.fr
Languages: French, English, Spanish, Italian, German
Demo: https://www.youtube.com/watch?v=67BBIwNT3Qw
Assistance / Support: by mail to dolibarr@joliciel.fr
Preconditions
    Version of Dolibarr min: 8.X     Version Dolibarr max: 24.X
Functionality
Generates a PDF file of the rest owed by customers :
And displays the outstanding amount owed by customers on the Dolibarr home screen.
1 - Download the module archive (.zip) file from the DoliStore.com website : https://www.dolistore.com/en/ [1]
2 - Place the file in the dolibarr root directory.
3 - Unzip the zip file, for example using the following command:
Unpack module_customersowed-1.0.0.zip
The module or theme is then available and activatable.
    Note: If your Dolibarr installation allows it, you can install your modules more simply from the "Install / Deploy a Module" tab on the modules page.
    Installation: https://www.youtube.com/watch?v=67BBIwNT3Qw
Update
From the history of your orders: select the order concerned, then under "Product", you have the link to download the latest version. The version number indicated on the link is the one of your initial purchase, the downloaded file will be the last version of the module.
Technical support
Website : www.joliciel.fr
Contact : dolibarr@joliciel.fr
