Module VolumeCalculator (EN)
Revision as of 18:41, 12 August 2026 by Increation (talk | contribs) (Create VolumeCalculator 1.0.0 English documentation)
VolumeCalculator module
Information
Module name VolumeCalculator
Publisher INCREATION
Status Stable, 1.0.0 candidate
Prerequisites Dolibarr 17 minimum
License GNU GPL v3 or later
VolumeCalculator calculates and stores dimensions and volumes on customer proposal, order and invoice lines.
  • Native line entry remains the default.
  • Manual activation through the “Volume” checkbox.
  • Automatic activation for products/services marked “Bill by volume”.
  • Width, height, depth and item-count entry.
  • Millimetre, centimetre or metre input.
  • Dolibarr quantity set from total volume or item count.
  • PDF output enhanced with dimensions and total volume.
  1. Deploy the archive from Home > Setup > Modules/Applications.
  2. Enable VolumeCalculator.
  3. Configure the unit and quantity mode.
  4. Enable “Bill by volume” on the relevant items.
Compatibility
Declared minimum: Dolibarr 17. Functional and visual tests performed on Dolibarr 17.0.4 and 23.0.2.
See also
