Module Smart Assistant
Revision as of 19:35, 9 August 2026 by Integ-mk (talk | contribs) (Initial draft)
Module ID 194000
Doc développeur du module Smart Assistant for Dolibarr - Technical overview
Smart Assistant - AI operations dashboard embedded in Dolibarr
Smart Assistant embeds an AI operations team inside Dolibarr. Five specialized agents continuously monitor your ERP data and turn it into prioritized, actionable recommendations - so business owners and managers spend minutes, not days, on operational review.
The module is a thin, open-source (GPLv3) connector to the hosted Smart Assistant service: all intelligence (agents, AI analysis, scheduling, recommendations) runs server-side on the service, accessed over HTTPS with a per-instance token and read-only access to the Dolibarr REST API.
  • Embedded dashboard - the AI dashboard renders inside Dolibarr (menu: Smart Assistant → Dashboard), following the Dolibarr light/dark theme.
  • Five specialized agents :
    • Revenue & Sales Ops - leads, opportunities, quotes, renewals, upsell signals
    • Customer Success - health scores, churn risk, retention plays, support trends
    • Procurement & Inventory - reorder points, supplier performance, stock forecasts
    • Operations Orchestration - process bottlenecks, stalled workflows, escalations
    • Business Intelligence - trend analysis, executive summaries, cross-agent coordination
  • Prioritized recommendations - every recommendation has a priority, a rationale, and (when it targets a single record) a direct link to the related Dolibarr page.
  • Human-in-the-loop actions - suggested actions are executed only after your approval.
  • Org memory - agents remember decisions and context across runs (no sensitive data is stored).
  • Continuous monitoring - agents run on a configurable schedule (weekday business hours by default).
Installation / Upgrade
  1. Install the module ZIP (Setup → Modules/Applications → Install external module) or copy the smartassistant folder into htdocs/custom/.
  2. Enable Smart Assistant in Setup → Modules/Applications.
  3. Open Smart Assistant → Setup : enter your Dolibarr URL and a read-only API key, then click Connect.
  4. Open Smart Assistant → Dashboard - agents begin their first analysis.
Requirements
  • Dolibarr 18+ (developed and tested against 23.x)
  • PHP 7.4+ (PHP 8 recommended)
  • Dolibarr REST API enabled with a read-only API key (created in Setup → API / user settings)
  • HTTPS on both the Dolibarr site and the hosted service
  • Module ID 194000 (reserved range 194000-194019)
Pricing & License
Component License Price
Dolibarr module (this package) GPLv3 or later Free
Hosted service (agents + dashboard) Proprietary SaaS Subscription - free during beta
The module is fully open source; the hosted service is a separate product requiring an active connection for the dashboard to work.
Links
