Module SMS Everywhere
Revision as of 10:00, 20 April 2026 by Mgribaudo (talk | contribs) (Creata)
The “SMS Everywhere” module allows the sending of SMS in the following situations
  • from ALL the modules that are enabled to send emails (offers, orders, shipments, invoices ….) by adding a specific button for sending SMS. The phone number used is that of the mobile phone of the event manager and / or event guest, in relation to the company connected to the event. If such contacts do not exist, the company’s telephone number is used. The event is created for the associated document (the action type is customizable in the setup)
  • from the events of the Agenda module
It also allows:
  • to send a reminder SMS to the customer or collaborators to whom the event has been assigned
  • to automatically send an SMS notification to customers of the event n hours before the event.
The telephone number is calculated with the logic described above
This module does not deal directly with the sending of messages, but requires the use of a third-party module for the forwarding of SMS
In this manual, the description of everything that follows the operating norms of Dolibarr is omitted, focusing only on the specific functions of the module itself.
Module configuration
The following parameters are required:
Sender Contains the sender of the SMS. The value to be assigned depends on the SMS provider used (in principle they should coincide)
Delay before sending Contains the minutes of delay for sending SMS
Priority Contains the priority of the SMS, also in this case, the value takes on different meanings (pricing for example) depending on the provider used
Reminder recipients Defines whether the reminders (remionder) should be sent to the Third Party or to the internal operators to whom the event has been assigned
International prefix Allows you to replace in all numbers starting with zero, the initial zeo with the prefix indicated (eg by indicating +33 in the field, 0340xxxxx will become + 33340xxxxx).
If you leave the value empty, the replacement will not be carried out.
Automatic SMS advance hours Contains the hours in advance, compared to the time of the event, for sending the automatic SMS
Automatic SMS Template Contains the template used for the automatic SMS. The list of templates present for the emails is proposed.
SMS Action Type Indicates the event type that will be used for the SMS sending event
Automatic sending of reminders for events in the Agenda
In the setup, indicate which model to use and the reminder advance time
Manual sending of reminders for events in the Agenda
On the Events page, there is a new Tab. From this it is possible to both send an immediate SMS and create a reminder (as shown in the image)
