Modules - Rules for community modules
Revision as of 12:08, 20 March 2026 by Eldy (talk | contribs) (Created page with "<!-- BEGIN origin interlang links --> <!-- You can edit this section but do NOT remove these comments Links below will be automatically replicated on translated pages by...")
Art.png Introduction
Here are the rules defined for all modules integrated into the community repository:
Art.png Rules
Compatibility
A modules added into the community repository can have prerequisites that differs from Dolibarr. So minimum and maximum version of PHP is not necessarly the same as the one of the Dolibarr version the module is compatible with.
Price
A module provided into the Dolibarr community repository must be free (as in speech but also as in beer).
It should not be sell on any platform, even on DoliStore (module may be available but for free).
Maintenance
The user that publish initialy the module in the community repository agrees to check and approve, on a regular basis, all Pull Requests submited related to its module.
If the module is a link to an external reference, the external link must be a forge based on Git.
  • Getting sources with a simple "git clone" with no need to create any account must be possible, for exemple using the "git clone" command with the http url of the repository (the source of the Git external repository is defined into the index.yaml file in the root directory of the module).
  • Contributing to sources must be as easy as doing a Pull or Merge Request. If the creation of an account is required for this, the creation of the user account should be possible from the forge in few seconds. No personal information should be requested (except a login or an email).
Date of validation
Rules need to be confirmed by the Dolibarr foundation ...
