Module PayPlug
Revision as of 14:43, 10 November 2025 by Eldy (talk | contribs)
Module name PayPlug
Dolibarr min version: 21
Last update date / Date mise à jour fiche / Fecha última actualización 2025-11-10
Add features to support PayPlug payment system.
Support PayPlug online payment page (credit/debit cards) inside Dolibarr. This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...).
From the application
Manually
unzip modulefile.zip
Dolibarr already generates the default payment links for customer invoices and member subscriptions, to allow customers to perform an online payment.
When the module is activated, all the links provided by Dolibarr to make online payments will include a button to switch to the Payplug checkout payment page.
Development and contributions
