Module HelloAsso
| Module name | HelloAsso |
Dolibarr min version: 21 |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2025-10-16 |
| Note / Nota |
Add features to support HelloAsso (also called "Hello Asso") online service for Association.
Support HelloAsso online payment page (credit/debit cards) inside Dolibarr. This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...). Option to support synchronization of members.
From the application
Manually
unzip modulefile.zip
Setup of HelloAsso Api
- First go on the page of the Association (create one from menu My login - Administer association - Add an association.
- Once you are on the page of an association, go into the menu My Account > Integrations and APIs
HelloAsso membership synchronization
You need the name of a form to synchronize HelloAsso members to Dolibarr. This can be done on your HelloAsso dashboard:
- First go on the page of the association (create one from menu My login - Manage the association - Add an association.)
- Once you are on the page of an association, go into the menu My memberships ( create one from button Create a membership)
- From there click on Manage
- Here you can find the membership form name to use later in setup
Setup of Dolibarr module
Setup for sandbox mode
3) Next you need to connect to your HelloAsso-sandbox account to get and fill the 3 following fields in Dolibarr:
- Client Organization name (of the organization you want the checkout to be done for. You can find the name in section My account - My association)
- Client ID test key (Blue square on the image)
- Client Secret test key (Red square on the image)
Setup for live mode
3) The next thing you need to do is enable the Live mode by enabling the Helloasso On/Live button.
4) Next you need to connect to your HelloAsso account to get and fill the 3 following fields in Dolibarr:
- Client ID live key (Blue square on the image)
- Client Secret live key (Red square on the image)
Setup of member synchronization
1) If you haven't already completed the Setup of Dolibarr module start by doing so.
Setup the membership form on HelloAsso
2) Next you need to connect to your HelloAsso account to get and fill the test membership form name and/or the live membership form name
Optional setup
Two optional setups are available.
HelloAsso and Dolibarr member type correspondence
This setup can be omitted if you don't want a specific Dolibarr member type to be linked to HelloAsso member types. The synchronization function will create a new member type in Dolibarr if no member type correspondence is set up.
To link a specific Dolibarr member type to HelloAsso member type:
1) First you need to get HelloAsso member type ID:
- Load the developer tools on your browser logged in to an HelloAsso administrator account of your organization (F12 on Mozilla Firefox)
- Click on the Network tab
- Replace the values between <> with your membership form in: (Example : https://admin.helloasso-sandbox.com/MyAssociation/adhesions/adhesion-helloasso/edition/2)
- https://admin.helloasso.com/<Organisation name>/adhesions/<Membership form name>/edition/2 and load it
- Or for sandbox mode https://admin.helloasso-sandbox.com/<Organisation name>/adhesions/<Membership form name>/edition/2 and load it
- Identify the
tiersfile returning a JSON type, and browse all the available tiers in theResponsetab, the tier ID is in the field namedid:
2) Next in HelloAsso module configuration, in membership settings tab. Find Dictionary of HelloAsso and Dolibarr member type correspondence part
3) Fill the two fields:
- Select box needs to be filled with Dolibarr member type to link
- Fill input with HelloAsso member type ID to link
4) Click on the Save button to save your configuration
This setup can be omitted if you don't have custom fields on HelloAsso form to synchronize with Dolibarr.
To link a Dolibarr member field to HelloAsso custom field:
1) First you need to get HelloAsso custom field slug:
- Log in to HelloAsso dashboard and go to the page of the association
- From there, click on Manage
- Now click on Step 3 Additional information
- You must see the page of information about your members. Look into the information to be provided; here are all the custom fields slugs
2) Next in HelloAsso module configuration, in membership settings tab. Find Dictionary of HelloAsso custom fields and Dolibarr field correspondence part
3) Fill the two fields :
- The select box needs to be filled with Dolibarr member field to link
- Fill the input with HelloAsso custom fields slugs to link
Usage of HelloAsso online payment page
Usage of member synchronisation
Once everything is set up, you can test the configuration of the synchronization function. To do so click on the button Test getting HelloAsso membership.
If there are no errors and a message is telling you that at least 1 member has been synchronized, you can now set up the scheduled job.
To enable the scheduled job:
- Access to Scheduled Jobs module configuration. Navigate to the Scheduled jobs tab.
- Next find the job with the label HelloAssoGetNewMembers
- Don't touch any of the configuration except for Run job every and Next execution
- Run job every defines how often the job will be executed.
- Next execution defines when the next execution will take place (After the first execution, this field will be automatically updated).
- Once everything is set up, click on Launch now to start the scheduled job
Development and contributions
- The documentation of HelloAsso API are available here: https://centredaide.helloasso.com/association?question=comment-fonctionne-l-api-helloasso
