Electronic Billing
Revision as of 19:36, 5 August 2025 by Eldy (talk | contribs) (Restore the page with Dolibarr support in each section of each country. In future, we will need a lot of space to enter detail of Dolibarr support, variant, etc. Using a table is not a goo way to adress this.)
<seo metak="einvoice, ereporting" />
This page presents a description of the rules and solutions for electronic invoicing (e-invoicing, e-billing) and e-reporting.
The laws, rules, and solutions to read, generate and/or send e-invoice depend on your country...
If your country is not in this list, feel free to develop your own interface module and publish it on any git source repository or packaged as a zip (for the price of your choice) on dolistore.com. But you can also do it as an alternative of an existing solution if a module already exists and does not match your need...
Belgium (Peppol BIS Billing 3.0)
Format
The electronic invoice format in Belgium is Peppol BIS Billing 3.0, which uses the UBL structure defined by the OASIS organization: https://docs.oasis-open.org/ubl/
Here are some links about this format:
Timeline
The Belgian parliament approved the law implementing mandatory domestic B2B eInvoicing in Belgium as from 1 January 2026
Dolibarr support
To generate invoices in this format, you may need to install the module: https://www.dolistore.com/fr/modules/1585-Peppol-XML---facture-electronique.html
The following module may also able to generate invoices but may also be able to send the invoice on the Peppol Network: https://www.dolistore.com/product.php?id=2427&title=peppol-full-integration-client (to be confirmed)
Legislation and current status
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Belgium
  • B2G: Yes
  • B2B: Not yet
  • B2C: No
  • VAT Real-Time Reporting: Not yet
Note: Belgium already offers a platform called Mercurius, where you can send manually classic invoice to get a Peppol invoice.
A peppol file can be validated here: https://ecosio.com/en/peppol-and-xml-document-validator/#
To know if a peppol file has been published on the peppol network, you can follow this tutorial: https://openpeppol.atlassian.net/wiki/spaces/Belgium/pages/624689399/Ma+facture+a-t-elle+t+bien+re+ue+par+le+client+Quel+est+son+statut
Colombia
Format
Factura Electronica Colombia DIAN
...To complete...
Dolibarr support
An old module is available here: https://www.dolistore.com/product.php?id=1205&title=factura-electronica-colombia-dian&l=en We have not got enough feedback to know it this module is still valid.
Croatia
Format
Compliant with the European standard (EN 16931)
Timeline
There are no current Business-to-Business (B2B) or Business-to-Consumer (B2C) eInvoicing mandates. However, a B2B mandate is under public consultation and is expected to take effect on 1 January 2026. Near real-time reporting is expected to begin in 2026.
Dolibarr support
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Croatia
  • B2G: Yes
  • B2B: No
  • B2C: No
Denmark
Format
Peppol BIS 3.0 and OIOUBL 3.0
Timeline
No mandate for B2B einvoicing yet, but under the 2022 Bookkeeping Act, businesses must ensure their systems are capable of sending and receiving eInvoices, including through Peppol and NemHandel
Dolibarr support
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Denmark
  • B2G: Yes
  • B2B: No
  • B2C: No
Estonia
Format
Peppol
Timeline
Since 1 July 2025 all accounting entities registered as e-invoice recipients in the commercial register are entitled to receive e-invoices by default.
Dolibarr support
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Estonia
  • B2G: Yes
  • B2B: Yes
  • B2C: No
Finland
Format
UBL 2.1 and Cross-Industry Invoice (CII)[3] or national formats such as Finvoice 3.0 and TEAPPSXML 3.0 (provided their compliance with the European Standard) or Peppol BIS Billing 3.0.
Timeline
There is no business-to-business (B2B) mandate.
However, under the eInvoicing Act 241/2019, companies with an annual turnover exceeding EUR 10,000 are entitled to request EN-compliant eInvoices from their suppliers.
Dolibarr support
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Finland
  • B2G: Yes
  • B2B: Partial
  • B2C: No
France (Factur-X, Peppol BIS Billing 3.0)
Format
The government has specified three types of electronic invoice formats:
  • Factur-X, sometimes incorrectly written as FactureX (Hybrid Format PDF A/3 + Structured Data in XML included in the PDF)
  • CIUS for Chorus Pro (Cross Industry Invoice (CII))
  • Peppol BIS Billing 3.0 (Universal Business Language (UBL) format)
Any of these formats can be used in France. The Dolibarr software has chosen the first format. It is already compatible (see below).
Timeline
Initially, the first deadline was set for January 1, 2024. The schedule was modified at the end of 2023 by the government. It is now as follows:
  • From September 1, 2026: Obligation to receive electronic invoices for all businesses.
All companies are required to receive their invoices in electronic format. Only large companies (employing at least 5,000 employees or with a turnover exceeding 1.5 billion euros) and medium-sized companies (employing between 250 and 4,999 employees or with a turnover not exceeding 1.5 billion euros) are required to issue invoices in electronic format.
  • From September 1, 2027: All SMEs and micro-enterprises will be required to issue electronic invoices (postponable until December 1, 2027).
Dolibarr support
To generate invoices in the Factur-X format, you need to install the FacturX module available on Dolistore:
This module, or a modified or Dolibarrized version of the module, will be integrated as standard in a future version of Dolibarr.
Once the document is generated, it must be transmitted to a centralized platform. Sending the invoice directly to your client via email will no longer be possible.
Dolibarr, like any invoicing software, will therefore need to interface with a PDP (private intermediary operator) or the PPF (the state's centralized platform for submitting invoices). This point has not yet been developed because the government platform and specifications for such automatic invoice transfer are not yet ready. The development will be carried out as soon as they are available. See the page GIFF Facture électronique.
Note: France already offers a platform called Chorus-Pro, where it is mandatory to submit invoices in certain cases (e.g., invoices intended for the administration). To interface your Dolibarr with this platform, you need to either submit invoices manually onto this platform, or to use a third-party service for submission directly from Dolibarr, for example by using:
Germany (Factur-X / ZUGFeRD, Peppol BIS Billing 3.0)
Format
The electronic invoice format in Germany is Factur-X, which is the same as in France. However, its German name, ZUGFeRD, can also be used. This standard involves integrating structured invoice data into an XML file embedded within the PDF A/3 of the invoice. All authorities at federal and national level are mandated to always offer a Peppol transmission if an automated data exchange is provided for the delivery of eInvoices. The XRechnung format being specific to Germany, economic operators should select a provider that is accredited by the German Peppol Authority. This ensures that the service provider conducts Peppol transactions in Germany.
Timeline
  • Mandatory issuance of eInvoices for companies with an annual turnover exceeding 800 000, 00 EUR. In 2027
  • Mandatory issue of eInvoice for every B2B transaction in 2028
Dolibarr support
To generate invoices in this format, you need to install the FacturX module available on Dolistore:
Greece (Peppol BIS Billing CIUS 3.0)
Format
The electronic invoice format in Greece is Peppol BIS Billing CIUS 3.0
Timeline
eInvoicing: From 1/7/2025 all companies are required to issue and receive their invoices in electronic format
Digital delivery note: From 1/4/2025 for companies with a turnover exceeding 200000€ and from 1/10/2025 compulsory for all legal entities
Dolibarr support
E-reporting is implemented by Independent Authority for Public Revenue (IAPR) MyDATA platform
Ireland
Format
PEPPOL BIS Billing 3.0.
Timeline
No Business-to-Government (B2G) eInvoicing mandate exists, but since June 2019, all public sector entities are required to receive and process structured eInvoices compliant with the European standard (EN 16931)
Dolibarr support
Italy (FatturaPA)
Format
The electronic invoice format in Italy is FatturaPA (national XML standard)
Timeline
As of January 2019, eInvoicing is mandatory for B2B and B2C for all Italian operators
Dolibarr support
There are two solutions:
Latvia
Format
Timeline
eInvoicing starting from 2028
Dolibarr support
Lithuania
Format
Timeline
mandatory eInvoicing targeted for 1 January 2028.
Dolibarr support
Luxembourg (Peppol BIS Billing 3.0)
Format
The electronic invoice format in Luxembourg is Peppol BIS Billing 3.0, which must comply with European standard EN 16931-1:2017. Two syntaxes are permitted:
  • XML UBL (Universal Business Language) defined in standard ISO/IEC 19845:2015
  • XML UN/CEFACT CII (Cross Industry Invoice)
Timeline
Dolibarr support
While there's no specific mention of Dolibarr support for Luxembourg e-invoicing, users can likely use the Peppol XML module available for other countries:
https://ec.europa.eu/digital-building-blocks/sites/display/DIGITAL/eInvoicing+in+Luxembourg
https://mindigital.gouvernement.lu/en/dossiers/2021/facturation-electronique.html
  • B2G: Yes (mandatory since 18 April 2019 or 18 April 2020 for sub-central contracting authorities)
  • B2B: No
  • B2C: No
Mexico (CFDIXML)
Format
CFDI XML
Timeline
Dolibarr support
To generate invoices in the Mexican electronic format, you need to install a CFDI XML module.
  • B2G: Yes
  • B2B: Yes
  • B2C: Yes
Norway
Format
EHF/Peppol BIS Billing 3.0
Timeline
Using Peppol is mandatory for invoices sent to administration
Dolibarr support
Poland
Format
Timeline
Poland plans to make business-to-business (B2B) e-Invoicing mandatory from 2026.
Dolibarr support
You may try to use the following module to transfer your invoice on Peppol: https://www.dolistore.com/product.php?id=2427&title=peppol-full-integration-client (to be confirmed)
Portugal
Format
OASIS UBL CIUS-PT and CEFACT CII CIUS-PT
Timeline
Dolibarr support
Romania
Format
RO_CIUS ensuring alignment with the broader European e-invoicing standard EN 16931.
Dolibarr support
Slovakia
Format
Peppol BIS 3
Timeline
Slovakia intends to introduce the mandatory B2B e-invoicing. Based on the mandatory e-invoicing, there will be on-line electronic reporting from January 2027, for domestic transactions (transactions with the place of supply within the territory of the Slovakia) and for taxable persons established in Slovakia. Cross-border B2B reporting (for intra EU transactions), based on e-invoicing, is going to be introduced from 1 July 2030.
Dolibarr support
Slovenia
Format
The national e-SLOG standard (version 2.0) is compliant with the EN 16931.
Timeline
Dolibarr support
Spain (FacturaE - VeriFactu)
Format
The electronic invoice format in Spain is called FacturaE (European standard EN 16931). VeriFactu is the system and network to send and validate invoices.
Timeline
B2B: The Law 18/2022 amendment mandates that all B2B transactions must be conducted using eInvoices. Businesses with annual revenues of EUR 8 million or more must comply within one year, while others have a two-year compliance period but it has not been officially issued yet.
Effective on 1 January 2026, the VERIFACTU system will become mandatory for all companies that are not subject to the SII Reporting mandate. This will require these companies to use certified accounting software and obtain invoice clearance for all their transactions.
Dolibarr support
One of the following module is required:
  • Module DoliFactu
A module called 2FacturaE exists to generated invoices using the invoice in the format expected (https://www.2byte.es/index.php/productos/modulo-2facturae). It was enough for spain.
But this is no more true: In 2025, you must also now have a software that keep tracking of recording payment and invoices into an unalterable way. For this you need now the module DoliFactu (https://dolifactu.es/producto/modulo-antifraude-dolibarr/).
Note also that there is also a ready to use hosting service called DoliFactu.es that includes this module by default in its offer.
  • Module LeyAntiFraudeYVeriFactu
Another solution to be ready and compliant with the VeryFactu system is to install the external module called "Ley antifraude y VeriFactu"
You can get the module here: https://www.dolistore.com/fr/modules/2259-Ley-antifraude-y-VeriFactu.html?search_query=verifactu&results=1
Note: As the law is evolving frequently and may depends on your business, you MUST check with your book keeper or your laywer that this suits completely the law and the need of your own business.
Sweden
Format
Timeline
Dolibarr support
Switzerland (QR-Bill)
Format
  • E-reporting:
Until 2022, Switzerland required invoices to be accompanied by a red payment slip (called BV) and an orange payment slip (called BVR). This is no longer the case. Instead, PDF invoices in Euro or Swiss Francs, which can or must be paid by bank transfer, must include, at the bottom of the page for example, a section containing all the information required for payment by transfer. This is called the QR-Bill or QR-Invoice.
Timeline
The "red payment slip" (called BV) and an "orange payment slip" (called BVR) is no more required after 2022.
QR-Bill is expected for PDF invoices in Euro or Swiss Francs, which can or must be paid by bank transfer since the 20th june 2020.
Dolibarr support
To obtain such a section:
  • You can install the following module: https://www.dolistore.com/fr/modules/286-SwissBanking.html
  • The other option is to activate the experimental option INVOICE_ADD_SWISS_QR_CODE:
    • Setting the value to '1' will generate and print the QR code only.
    • If the option is set to 'bottom', the entire section at the bottom of the invoice will be displayed, but the installation of an external PHP library will be requested at the first generation of the PDF.
  • B2G:
  • B2B:
United Kingdom
Format
The electronic invoice format must follow Peppol (to be confirmed).
Timeline
Using Peppol is mandatory for invoices sent to administration (to be confirmed).
Dolibarr support
Other / Resources
More resources can be found: https://www.tx2.fr/en/2024/01/15/electronic-invoicing-europe-regulations-obligations/
