Integration of Dolibarr to the Airbyte data integration platform
Revision as of 06:23, 4 July 2025 by Leonm2 (talk | contribs)
Airbyte is an open-source ELT platform that allows to create data integration streams with no code interface, in this tutorial will be explained the use of the Dolibarr source connector available in the marketplace of the different options of Airbyte installations. This connector also could be edited, personalized, and updated to contribute by the users through the graphic UI Connector Builder of the Airbyte platform.
Prerequisites
For this guide you need to complete the following prerequisites:
  • Create an instance of Dolibarr (in cloud SaaS service, on-premises installation with a public URL or in a cPanel server or hosting server) and configure it to use SSL encryption (with the HTTPS protocol)
  • Create a Dolibarr user account with administrator rights.
  • Activate the “Web Services API REST” module following the official documentation
  • Generate an API key for your current admin user account or create a new user to generate in this new user the API Key that you will use to execute the data integration streams.
  • Give read permissions, to the user with the API key generated, for the modules that will be source of data in the data extraction streams. (Some streams or end points, like GET company information, will require that your user be administrator or have read/write permissions to works fine with the GET end point)
Create the Airbyte Connection
Access to your Airbyte installation.
If you don’t have it, you could follow the next guide: https://docs.airbyte.com/platform
For the Open Source version: https://docs.airbyte.com/platform/using-airbyte/getting-started/oss-quickstart
When you have your Airbyte instance, now you can create a connection where you will select a source and destination. In this guide we will only do the Dolibarr source connector configuration, but you can select any destination connector from the available options and follow the specific configuration guide for each one.
Select Dolibar source connector.
Dolibarr source connector selection in Airbyte
In the home page of your Airbyte installation select the bottom “Create Connection”, then you will be able to select the source connector from a list. You must select Dolibarr connector from the Marketplace connectors list.
You can find additional documentation of the Dolibarr source connector in: https://docs.airbyte.com/integrations/sources/dolibarr
Enter the authentication credentials for the Dolibarr connector:
After selecting the Dolibarr source connector you will be required to enter the public domain of your Dolibarr instance (please follow the Dolibarr connector instructions that appears in Airbyte) and the API key that you previously configured for your Dolibarr user.
Additionally, you must enter the “Start Date” that defines the oldest date of the data you want to synchronize.
Dolibarr source connector authentication credentials configuration in Airbyte
Airbyte will make a connection test previously to save the configuration and let you continue to the destination configuration. For the destination you must follow the configuration guide for your selected connector.
Select the sync mode and streams for the schema:
After the source and destination connector configuration, you need to select the sync mode you want and the streams and fields you want to include in your schema of the data you will extract and synchronize. For each stream in your schema, you will be able to select the sync mode, is recommended to select “Full refresh | overwrite” initially and if you want to enable the incremental sync modes you will need to validate the compatibility with your destination doing some sync tests.
Dolibarr source connector - sync mode, streams and fields schema selection in Airbyte
As a guide to select the streams and fields for your schema you could keep in mind the streams and fields description table below. Some fields where modified or created inside the Dolibarr source connector and may not match with the original Dolibarr database field names.
Remember that your Dolibarr user with the API key must have the adequate permissions for the modules related with the streams and fields you are extracting for synchronization.
Overview of streams or data tables with important column names on each sheet and their corresponding meaning
- Product list stream (list of all products)
barcode Product barcode
cost_price Purchase price (manually defined cost price)
date_creation creation date in Unix timestamp format
date_modification Date of modification in Unix timestamp format
label Product Name
pmp Average purchase price (cost price calculated from supplier invoices)
price_min_ttc minimum sale price (maximum discount)
price_ttc Sale price
product_id Product Identifier
ref Product reference
status Availability for sale status
status_buy Availability for purchase status
stock_reel actual inventory to date
stock_theorique Theoretical inventory stocks to date
- Products category id list stream (listing of all product ids with their respective product category id)
category_id Product Category Identifier
- Product categories list stream (listing all product categories)
description Product Category Description
label Product Category Name
- Customer invoices list stream (list of all sales invoices to customers to date)
customer_id Identifier of the customer to whom the sale was made
date_validation validation date in Unix timestamp format
invoice_id Customer invoice ID
module_source Invoice generator module
multicurrency_code Used Currency Code
paye invoice payment status
pos_source POS-generated invoice status
ref Customer Invoice reference
total_ttc Total amount of the invoice including taxes.
totalpaid Total invoice payment amount
user_creation_id Creator User ID
user_validation_id validating user identifier
- Customer invoices lines list stream (list of all product lines associated with all customer invoices)
description Manually entered product or service name
invoice_id ID of the customer invoice to which the line corresponds
marge_tx Profit margin over the purchase price of the line
marque_tx Profit margin over the sale price of the line
product_barcode Product barcode
product_id product identifier on the line
product_label Product Name
product_ref Product reference
qty Quantity of products
total_sell_price Total sale price of the line
unit_buy_price Purchase unit price or cost of the product in the line
unit_sell_price unit selling price of the product in the line
- Customer invoices payments list stream (list of payments associated with each customer invoice)
amount total amount of the payment.
date date of payment.
invoice_id Identifier of the invoice to which the payment belongs.
num Reference of the customer invoice to which the payment belongs.
ref Payment identifier.
type type of payment (CB: credit card, LIQ: cash, PRE: debit payment order, RAP: Rappi transfer, VIR: bank transfer).
- Customers list stream (list of all customers)
address Residence address.
client client status.
code_client Customer reference code.
country_code country code of residence.
customer_id customer identifier.
email Email address
fournisseur supplier status.
idprof1 R.U.T.
idprof2 Citizenship card/NIT/Foreigner's card
name Customer's name.
name_alias short name of the client.
phone telephone.
prospect Prospect status.
status active or inactive status.
town city or town of residence.
url Website Address
- Supplier invoices list stream (list of all supplier purchase invoices to date)
date_echeance payment deadline in Unix timestamp format
datec creation date in Unix timestamp format
ref Supplier invoice reference
supp_invoice_id Supplier invoice ID
supplier_id Supplier ID from whom the purchase invoice was received
tms Date of modification in Unix timestamp format
- Supplier invoices lines list stream (listing of all product lines associated with all supplier invoices)
buy_unit_price Purchase unit price or cost of the product in the line
supp_invoice_id Identifier of the supplier invoice to which the line corresponds
total_buy_price Total purchase price of the line
- Supplier invoices payments list stream (list of payments associated with each supplier invoice)
supp_invoice_id Identifier of the invoice to which the payment belongs.
- Suppliers list stream (list of all suppliers)
address Residence Address
client Client status
code_fournisseur Supplier reference code
country_code Country code of residence
email Email address
fournisseur Supplier status
idprof1 R.U.T.
name Supplier Name
name_alias Supplier's short name
phone telephone
prospect Customer Prospect Status
status Active or inactive status
supplier_id Supplier Identifier
url Website Address
- Internal Users stream (list of company users in the ERP/CRM system)
datelastlogin date of last login in Unix timestamp format
datem date of user modification in Unix timestamp format
datepreviouslogin date of prior entry into the system in Unix timestamp format
email User's email address
firstname User Name
job role or job within the company
lastname User's Last Name
office_phone Work Office Phone
user_id User Identifier
user_mobile cell phone
- Company profile data stream (ERP/CRM company profile data)
address Business or premise location address
company_id Company identifier in the ERP system
country_code country code of operation
default_lang Default language
email Email address
idprof1 R.U.T.
idprof2 Legal ID/NIT of the company
managers Names of the administrators
name Legal Company name
phone telephone
socialnetworks Social Media URLs
town city or town of company location
url Website Address
zip zip code
Final connection configuration:
Dolibarr source connector - final connection configuration in Airbyte
Finally, you must configure the name, schedule type, frequency and destination namespace for your connection. After these definitions you could save your connection and Airbyte will execute the first synchronization.
Go further
The Dolibarr source connector in Airbyte will let you modify and customize the streams, fields and API methods used by editing the connector in the UI Connector Builder, is important that you explore the Airbyte public documentation (https://docs.airbyte.com/platform/connector-development/connector-builder-ui/overview ) to make improvements to your connectors and get the maximum benefits of the Dolibarr data integration with this tool and contribute to the connector update.
Conclusion
Airbyte is versatile and powerful open source tool that allows you to create a no code data integrations between Dolibarr and many third-party applications using the Wbe services API REST to explode your operational data in analytics, business intelligence, AI tools to have added value from your data to make business decisions.
