Module HelloAsso
Revision as of 21:56, 23 June 2025 by Eldy (talk | contribs)
Module name HelloAsso
Dolibarr min version: 21    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2025-06-23
Add into Dolibarr a HelloAsso online payment page (credit/debit cards). This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...).
From the application
Manually
unzip modulefile.zip
Setup of HelloAsso Api
  • First go on the page of the Association (create one from menu My login - Administer association - Add an association.
  • Once you are on the page of an association, go into the menu My Account > Integrations and APIs
Setup of Dolibarr module
Setup for sandbox mode
3) Next you need to connect to your HelloAsso-sandbox account to get and fill the 3 following fields in Dolibarr:
  • Client Organization test with the organization you want the checkout to be done
  • Client ID test key (Blue square on the image)
  • Client Secret test key (Red square on the image)
Setup for live mode
3) The next thing you need to do is enable the Live mode by setting On Helloasso live enabled button.
4) Next you need to connect to your HelloAsso account to get and fill the 3 following fields in Dolibarr:
  • Client Organization live with the organization you want the checkout to be done
  • Client ID live key (Blue square on the image)
  • Client Secret live key (Red square on the image)
Development and contributions
Troubleshooting
