Module Receipt Printer
Revision as of 00:20, 13 June 2025 by Eldy (talk | contribs)
Receipt Printer
Numero/ID of module 67000
Developer doc. of module
This module allows you to add a receipt printer manager to your Dolibarr. The printer can then be used via the TakePOS Point of Sale (POS) module to print sales receipts.
Example of validated hardware and configuration
TODO
