Module Belgium EN
Revision as of 12:44, 14 May 2025 by Eldy (talk | contribs)
Module name Belgium
Editor / Editeur Laurent Léonard - http://www.open-minds.org
Last update date / Date mise à jour fiche / Fecha última actualización 2025-05-14
It allows you to generate and publish InterVAT documents.
Go into new menu entry "Belgium" to find all new features.
Development of this module is not included inside standard CVS repository of Dolibarr but into the private complementary modules area DoliForge. So source code is hosted into following source repository:
