Module Compare
Revision as of 00:15, 10 May 2025 by Eldy (talk | contribs) (→‎Development Info)
Module name Compare
Editor / Editeur Seth Rickert – Apex Tech Mods Apex Tech Mods
Dolibarr min version: 16.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2025-05-10
Dolibarr Compare Module
The Compare module provides a powerful side-by-side page viewer inside Dolibarr. It allows users to compare up to five different Dolibarr pages simultaneously using draggable iframes. Each column can be independently reloaded, resized, toggled between desktop/mobile views, and printed with clean formatting.
Built entirely without modifying Dolibarr core files, Compare integrates seamlessly and remains compatible across updates.
Key Features
  • Compare up to five Dolibarr pages side-by-side
  • Draggable vertical divider layout
  • Support for desktop/mobile toggling per iframe
  • Persistent session data using browser localStorage
  • Print-optimized layout with auto-numbered pages
  • Toolbar controls for reloading, view switching, and layout resets
  • Optional top icon and left sidebar menu entry (configurable)
1. Download the ZIP package from [DoliStore](https://www.dolistore.com/en/modules/compare-module.html) or [1](https://apextechmods.com).
2. Upload it to the `/custom` directory of your Dolibarr instance.
3. Go to Home → Setup → Modules → Deploy external module and install it.
4. Enable it via Setup → Modules.
5. Configure links via Setup → Modules → Compare → Setup
Navigate to the Compare module from:
  • The top icon (if enabled)
  • The left menu under "Home" (if enabled)
You can load any Dolibarr internal URL (card pages, lists, forms) into each of the columns. Controls appear above each iframe for customization.
Screenshots
Dolibarr Compare Module Screen Capture
Translations
English, French, Spanish, German, Portuguese (Brazil), and Italian
New translations can be added by editing or adding the files in the `/langs/` directory of the module.
Development Info
  • Module ID: 220020
  • No core override – fully modular
  • Written for PHP 7.1+
  • Custom config: `COMPARE_TOP_ICON_ENABLED`, `COMPARE_LEFT_MENU_ENABLED`
  • Created by: Apex Tech Mods
Download
Categories
Modules/Plugins
  • Reporting or search
  • User's interface
  • System tools
