Module DoliPos
Revision as of 18:09, 31 March 2025 by Eldy (talk | contribs) (→‎Informations)
Module name DoliPOS
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2025-03-31
This module is a POS terminal or POS Professional, which provides sales on a counter with the public. With this unique system of point of sale, we can create all terminals (cash) needed, and manage with a single product, with unlimited users, and through the WEB.
More info(Spanish only)
Module info by official developer: www.2byte.es
Acquire the module: www.dolistore.com
Test on DoliCloud: www.dolicloud.com
