Roadmap and Release 21.0.0
Revision as of 10:50, 11 March 2025 by Eldy (talk | contribs)
Version: 21.0 (List of other versions on page Category:RoadMap)
Release date: 27/02/2025
Fr verysmall.png https://www.atm-consulting.fr/decouvrez-les-nouveautes-dolibarr-v21/
Detailed Changelog:
For users:
NEW: NEW Module - help to setup OpenID Connect (#30317) NEW: Module AI moved from experimental to stable NEW: Add hidden option CONTRACT_HIDE_MYCOMPANY_SIGNATURE_SECTION_PDF NEW: Add a tab on recurring invoice card to see the list of invoices generated from this recurring invoice (customer and supplier invoices) (#31463) NEW: #28871 signed_status to commande (#30359) NEW: #30269 linked project in column of last record tables (#30344) NEW: Accountancy - Add general account on thirdparty NEW: Accountancy - Add partial reconcile on subledger (#30027) NEW: Accountancy - Option to select the label of operation (#31200) NEW: Accountancy - Allow grouping taxes with primary line price (#26732) NEW: Activate PHPUnit with tests on permission on $action ==... NEW: Add advice for max size on list for better performance NEW: Add an advanced permission to validate knowledge (#30855) NEW: Add a test mode into the setup of AI module to test the AI prompts. NEW: Add a tool to decrypt data encrypted in database. NEW: Add auto generate document when reception is created (#30688) NEW: Add badge for generate invoice client tab (#31559) NEW: Add caldav on fichinter (#30582) NEW: Add column agenda_id to implement the link between files and event NEW: Add column "comment" in list of payment NEW: Add constant to hide version (#30865) NEW: Add country in search of project NEW: add duration extrafields (#31595) NEW: Add export for thirdparty bank accounts (#30807) NEW: Add export profile to export MO and lines of consumption/production NEW: Add option to store the text content of uploaded files into database (with conversion with pdftotext) NEW: Add Filter Assistance for Filling Filters Field (#31646) NEW: add last stock movement and product nature to StocksWithBatch export (#30578) NEW: Add member title to the labels (#31710) NEW: Add mode Customer price + level price (#31091) NEW: add option to add external billing contact on the supplier_proposal pdf (#30298) NEW: Add option to clone its default BOM when cloning a product (#30088) NEW: Add option to enable PDF frame rounded corners NEW: Add option to round weight and volume on shipment PDF NEW: add pdf regeneration to mass action for shipments (#29970) NEW: Add picto on list of notification email templates NEW: add recurring supplier invoice on supplier tab #30945 #30949 NEW: Add sort by ref warehouse/product or ref product/warehouse on inventory product list (#31639) NEW: Add some improvement for ODT Contracts (#31715) NEW: Add terms of sale on documents (#24846) NEW: Add thirdparty state in substitution array (#31549) NEW: Add tooltip on closing accounting setup NEW: add trigger for linking and unlinking invoices (#30182) NEW: Add Unit price on supplier order stat product (#31055) NEW: add warehouseId parameters in select_produit to limit result to existing product in select (#30477) NEW: allow link feature to task (#30235) NEW: Authorize modification of a partially shipped order (#31423) NEW: autogenerate project reference in API (#30638) NEW: automatically change status on answering a ticket (#30556) NEW: Browser notifications use now jnotify (fix browser compatibility) NEW: can add extrafields with dol_move (#30574) NEW: Can change the type of a social contribution if no payment NEW: can delete a category translation (#31396) NEW: Can link an object to another using the ref. Close #31001 NEW: Can set a class on the tr lines of form setup lines NEW: Can set border radius of list and tables NEW: Can set date of transmission in 1 click when validating SEPA NEW: Can set parameters with setup type yesno. NEW: Can set the contact type for the autoassigned user that creates a project (#30444) NEW: Can show raw value of oauth token NEW: Can use a specific profile to send email for password forgotten NEW: option to care grandchild (#31314) NEW: Look and feel - checkbox to choose thirdparty nature (#30192) NEW: Color line total and sub total (#26172) NEW: Constant to hide user login times (#29815) NEW: Const ASSET_ROUND_INTEGER_NUMBER_UPWARDS for ASSET Module. Compatibility to migrate from other accounting solutions. (#31615) NEW: Content of tab "attached files" is more compact. NEW: Contract signed status update (#30779) NEW: Create thirdparty notification by action code (#30541) NEW: Customer price and level price together NEW: default configuration for event reminder (#31407) NEW: determine multi-currency price on object line create tpl (#28021) NEW: Display for socialnetworks admin NEW: display mark rates in objectLineCreate (#30872) NEW: due date in accounting bookkeeping list and card (#30061) NEW: enhance the OAUTH2 token manager. Can refresh a token from page. NEW: EPC QR CODE - Use bank owner account name instead of company (#31735) NEW: fichinter list disable details option (#30884) NEW: filter on invoice dates in product margin tab (#29997) and thirdparty margin tab (#29998) NEW: FIX: Display invoice widgets by amount instead of number (#30215) NEW: Add the Clone of company (#29755) NEW: function for Preview In CKeditor products NEW: FY Changed Period handle in Module Asset (#31618) NEW: hidden option MAIN_TE_PRIVATE_FIRST_AND_LASTNAME_TO_UPPER (#31143) NEW: Hide completed items in Link to (#31329) NEW: Iban is saved encrypted NEW: if a user is associated with the expense report, then that user will get an associated credit line ($tabtp) generated. NEW: Implementing Billable tasks on projects using new attribute "billable" (#30092) NEW: Include a protection into check update of module to detect malware NEW: intervention signed status update (#30629) NEW: INTRA VAT ID field optionally mandatory and/or invoice mandatory in thirdparty module setup (#31663) NEW: Invoice - Generate payment information - Structured communication (#31376) NEW: Invoice line import - fk_product can be a ref (#30795) NEW: Look and feel v21 - Can have rounded border on tables NEW: Look and feel v21 - Toolbar for WYSIWYG editor is short on smartphone NEW: Management of extrafields on customer prices, level prices and default prices (#31313) NEW: manage several type of dangerous goods for a same parcel (#30238) NEW: Member - Can upload a file with drag and drop (#30265) NEW: Move the picto in the first tab label always visible NEW: ODTSubsitution for date_start_real / Contracts NEW: Look and feel - Opacity for finished lines (#30219) NEW: option: assign default roles to "individual" third-party contacts (#30499) NEW: option to allow freezing qty in BOM service's line (#29990) NEW: Add a page to list the lines of orderse (#31521) NEW: pagination in product margin tab NEW: payment term and mode on creating supplier (#31166) and third-party (#31067) NEW: PDF Add Customer accountancy code (#31544) NEW: PDF Add discount total if line discount exists (#31483) NEW: PDF Add option to print rounded corner frames (#31172) NEW: PDF Add shipping address in sales orders (#31293) NEW: PDF Add total discount if line discount exists NEW: PDF frame rounded corners NEW: Prelevement - Use structured payment data for Belgium (#31383) NEW: Preview product list when we choose model email layout Commerce (#30185) NEW: Can upload a file with drag and drop: Thirdparty (#30263) - Product/Service (#30250) - Project (#30276) - Propale (#30315) NEW: Public and private note options in thirdparty list (#31062) NEW: redirect to expedition card if global search has unique result (#30108) NEW: replenishment if the warehouse is set to the default selected user (#31229) NEW: retrieve Thirdparty by account (#31283) NEW: Share msg "not found" for widgets and add a button to add new record when none exists (#31309) NEW: shipment signed status update (#30928) NEW: Show detail of each multicurrency amount in popup of price NEW: show holidays at bottom of activity/permonth.php page (#31550) NEW: Show tooltip on number of qualified records NEW: Signature or proposal from the Web portal (#30062) NEW: Star Field Type for Extra Fields (#31348) and for for Module Builder (#31216) NEW: Support option PDF_ADD_POSITION on shipment espadon template NEW: Auto-suspend facture rec when nb gen max is reached (#31623) NEW: The margin section can now be shown/hidden NEW: Deal change in fiscal year period adjustments to shortened or extended periods (e.g., fiscal years of 9 or 15 months) NEW: (ticket, admin): More options entries (#30548) NEW: Update warehouse product list to add another sorting option (#30971) NEW: Can set blacklist of words into answer of AI (#30385) NEW: user list country filter (#30770) NEW: vat rate with department in dict (#31628) (#31627) NEW: When we export data of unlaterable log, we add an unalterable line in logs NEW Add option THEME_STICKY_TOPMENU = 'scrollleftmenu_after_mainpage' (or 'disabled') NEW value for FICHINTER_DISABLE_DETAILS. If FICHINTER_DISABLE_DETAILS is set to '2' details are disabled only on intervention list. SEC: security avoid RCE using -'- sequence to pass --checkpoint-action parameter in tar command. SEC: FIX Security path transversal with modulepart=medias (viewimage.php and download.php) PERF: Reduce nb of requests into num_public_holiday PERF: Reduce size for VCF files and virtualcard qrcode PERF: Reduce time to show the page of unalterable logs with high data For developers:
NEW: translation with action triggers API (#30595) NEW: more complete stock product API call (#30567) NEW: Projet - Add hook formconfirm (#31408) NEW: Can choose the zip handler to build ODT. NEW: Can force ip into log file name using a define('SYSLOG_FILE_ADDIP') NEW: Can force log file name using a define('SYSLOG_FILE_ADDSUFFIX') NEW: Can define the text on tooltip on a yesno check. NEW: Introduce value 'password' for mode of sanitization in GETPOST. NEW: Add getImageFromHtmlContent() method NEW: Add gitleaks into pre-commit NEW: Add hook after the line is processed in the sell journal page (#31439) NEW: add hook dolibarrDelConst (#30672) NEW: Add hook getLoginPageExtraContent, getPasswordResetPageExtraContent NEW: add hook in dolibarr_set_const admin.lib.php (#30605) NEW: Add hook on sell journal page for overwrite the processed journal data after the SQL request (#31033) NEW: force_install_noedit : add value 3 to block all technical parameters excepted main_url (#30080) NEW: Add a new hook on order list (#31315) NEW: Add ID of the line in the trigger context for addLine(), updateLine() and deleteLine() on contract (#30343) NEW: Add more log information NEW: Add pagination data to some api routes (#29895) NEW: Add test to forbidden NOW() SQL function. NEW: API call to re-generate a users password. (#30590) NEW: API close proposal now supports both private and public note (#30659) NEW: API_LOGINS_ALLOWED_FOR_GET_EXTRAFIELD (#30562) NEW: API /setup endpoint for getting action triggers (#30538) NEW: HOOK FORMCONFIRM IN TICKET (#31321) NEW: hook on expensereport added (#31380) QUAL line classes for various business object classes have been moved to individual files. QUAL: #30122 (#30131) QUAL: AccountancySystem: maintenance work to uniformize and clean up (#31391) QUAL: All $conf->global->module->enabled are replaced with isModEnabled() QUAL: bankline category table name (#30419) QUAL: Clean code QUAL: conformity PR for data structure of #29964 (#30014) QUAL: Edition of currency is shared in a common tpl file QUAL: Ergo btn and fix (#30947) QUAL: Move function csvClean into functions2.lib.php QUAL: Move the public css file into the public directory QUAL: Removed inclusion of the file json.lib.php QUAL: simplifying readability of sql QUAL: Standardize name of user cookies QUAL: Suffix table name to have them created on module install QUAL: The property ->domiciliation and ->propio on bank accounts has been QUAL: Update inc.php (#29822) QUAL: Use archiveOrBackupFile for MAIN_MAIL_DEBUG_LOG_WITH_DATE QUAL: Use table_element in sql queries (#31355) QUAL: rename const WORKFLOW_EXPEDITION_CLASSIFY_NEWD_INVOICE to WORKFLOW_RECEPTION_CLASSIFY_NEWD_INVOICE QUAL: This configuration change in phan will report NEW: array types in phpdoc WARNING:
The following changes may create regressions for some external modules, but were necessary to make Dolibarr better: * Prepare your module for deprecation of triggers code XXX_INSERT to support also XXX_CREATE. * More class properties (with old name in french) are now deprecated in favor of the property name in english. * The json emulator dol_json_encode/decode() is removed. The native json PHP module must be enabled/available (this is the case by default with most PHP installation). * The deprecated GET parameter "&sall=" has been removed, use now the "&search_all=". * The experimental and deprecated module WebserviceClient is completely removed (was never released and use deprecated architecture). It may be replaced with the stable module Webhook. * The dynamic properties ->no_button_delete, ->no_button_edit, ->no_button_copy for $object Product that could be set by an external module must no more be set (not allowed by PHP 8.2). A module can already return an array with key 'no_button_delete', 'no_button_edit', 'no_button_copy' for the same purpose. * The old function dol_bc($var, $moreclass = ) has been removed. If you called it, just stop to call it (the function has no effect since a long time). * The trigger code CATEGORY_LINK and CATEGORY_UNLINK have been replaced with code CATEGORY_MODIFY. You can read ->context['linkto'] or ->context['unlinkoff'] to detect if we want to make a link or unlink. * The property ->domiciliation and ->propio on bank accounts has been deprecated and replaced with property ->address and ->owner_name everywhere. * If you were using the substitution key __MEMBER_CIVILITY__, you must now use __MEMBER_TITLE__ * The hidden title of tab that was hidden by the CSS class tabTitleText has been completely removed from HTML content.
