Module Ticket
Revision as of 11:44, 5 March 2025 by Ahau (talk | contribs) (→‎Introduction)
Ticket
Numéro/ID du module 56000
Doc développeur du module Module Ticket (developper)
This module allows you to manage a Help Desk service. You can create and follow tickets from the backoffice but also from a light public portal.
Public interface
There is a public interface available to create an view tickets: <your dolibarr URL>/public/ticket/
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regarding Captchas on public pages.
Workflow
The default workflow of a ticket is (number in parenthesis is the numero of status):
                                             --> on Hold (7) --->
Not read (0) ---> Read (1) --> Assigned (2) --> In progress (3) ------------>  Closed/Solved (8)
 |                                     Waiting feedback requester (5)
                      Canceled (9)
Create a ticket from the backoffice
  1. Click "Ticket" to activate the Ticket module
  2. Click "New Ticket" on the left column
  3. Fill in the fields
  4. Click "Create Ticket"
  5. Done
Create a ticket from the public interface
