Integration of Dolibarr to the Make automation platform
Revision as of 17:21, 29 January 2025 by Eldy (talk | contribs)
This tutorial explains how to create a Make integration for Dolibarr using an integration that creates events in the agenda module as an example.
The integration will be between your own Dolibarr and the official online Make.com platform. It will need to setup the Make.com platform to defined the Dolibarr messages you want to interact with.
Note that you may also fine a ready to use integration (with most Dolibarr API already available with no setup step), by using the platform StartIntegrate platform.
Prerequisites
The following tutorial assumes that you have completed the following prerequisites:
  • You have access to an instance of Dolibarr configured to use SSL encryption (with the HTTPS protocol)
  • You have access to a user account with administrator rights
  • You have activated the “Web Services API REST” module (if it is not already the case, follow the official documentation)
  • You have obtained an API key for your user account that you will use to test your integration (generated by an administrator, or by the user himself if he has permission to modify his user account information)
When necessary, we will use the following URL to refer to your Dolibarr instance: https://yourdolibarrurl. You will have to replace it with the URL of your own Dolibarr instance, without trailing slash.
Create the Make application
  1. Go to https://eu1.make.com and log into your user account
  2. Go to the My Apps tab
  3. Click on Create a new app. You can call it Dolibarr. This instance will contain a connection and several modules that will implement specific features such as creation of a task or creation of an event for instance.
In the Base tab, you just have to write
Configure authentication
It is essential to link the Make application (i.e Dolibarr) to the external application via a connection, which can be set in the connection tab of the Make application.
This tab has two sub-tabs : Parameters tab and Communication tab.
NB : The applications that a user can create on Make are written in json.
a) Parameters tab
There are three required parameters for the connection : the Dolibarr API key, the URL of the Dolibarr instance (https://yourdolibarrurl for instance) and your user ID. It means these parameters require some values in order to create a connection. Thus, you can write the following code :
        "name": "apiKey",
        "type": "text",
        "label": "Dolibarr API key",
        "required": true
        "name": "hostname",
        "type": "text",
        "label": "Dolibarr instance URL",
        "required": true
        "name": "userownerid",
        "type": "number",
        "label": "User ID",
        "required": true
NB : In each tab, save the written code with Ctrl+S
b) Communication tab
The following code specifies the account validation process.
    "url":"{{parameters.hostname}}/api/index.php/users/info",
    "headers": {
        "DOLAPIKEY": "{{parameters.apiKey}}"
    "log": {
        "sanitize": ["request.headers.DOLAPIKEY"]
Create an action module
Example of module to create events in the Dolibarr calendar
As a reminder, the goal is to implement the following use case : As soon as you receive a mail on an Email box, report it in Dolibarr events
In this case, the Dolibarr instance receives information from the Email application. In this case, the Email application is a trigger generating an action in Dolibarr.
On the Dolibarr side, the module to implement is an action module, that we can call Creation of an event. This module can be configured in different tabs which are detailed below. The different tabs are connected so that some parameters can be used in a tab that is different from itself.
a) Communication tab
This tab contains the different required parameters that will be transmitted from the Email application to Dolibarr. The required parameters are the one required by the API.
You have to fill the code block of this tab as follows :
    "url": "{{connection.hostname}}/api/index.php/agendaevents",
    "method": "POST",
    "qs": {},
    "body": {
        "type": "Email reception",
        "label": "{{parameters.label}}",
        "type_code": 6,
        "userownerid": "{{connection.userownerid}}",
        "email_sender": "{{parameters.name}}",
        "email_from": "{{lower(parameters.email)}}",
        "percentage": "-1",
        "status": "0",
        "date_creation": "{{parameters.date}}",
        "datep": "{{parameters.date}}",
        "datef": "{{parameters.date}}"
    "headers": {
        "DOLAPIKEY": "{{connection.apiKey}}"
    "response": {
        "output": "{{body}}"
NB : In each tab, save your code with Ctrl+S
Explanation of the different required fields :
API field Description Type Possible value
type Event type text Email reception
label Event label text New emails received
type_code Dolibarr event type code number 6
userownerid Dolibarr user that create the event number 7
email_sender Login of the sender text jdoe
email_from Email address of the sender text john@doe.org
status number 0
percentage Event progress number between -1 (N/A) and 100 -1
date_creation Date of creation of the event date 2023-03-12T18:25:43-05:00
datep Start date of the event date 2023-03-12T18:25:43-05:00
datef End date of the event date 2023-03-12T18:25:43-05:00
The type_code “6” corresponds to the event type “Email reception”.
NB : Bold parameters are compulsory for this scenario
Select a connection : Under the previous code block, you have to select a connection. Select the Dolibarr connection that you created previously.
b) Static parameters tab
        "name": "type",
        "type": "text",
        "label": "Type",
        "value": "Email reception"
c) Mappable parameters tab
The following parameters are mappable, that means it must be completed by the user.
        "name": "email",
        "type": "email",
        "label": "Email address",
        "required": true
        "name": "name",
        "type": "text",
        "label": "Name",
        "required": true
        "name":"label",
        "type":"text",
        "label":"Mail label",
        "required": true
        "name":"date",
        "type":"date",
        "label":"Received on",
        "required": true
d) Interface tab
        "name": "id",
        "type": "uinteger",
        "label": "User ID"
Your integration is now ready to be used.
1st scenario : Report an email in Dolibarr events
1) Create a new scenario
  1. Click on the Scenarios tab of the left-hand menu
  2. Click on the Create a new scenario button at the top right
2) Email scenario configuration
2.a) Email scenario initialization
  1. Click on the + symbol to add a module
  2. Select the Email module, that you can search it at the bottom of the drop-down list.
  3. Select the Watch Emails trigger of this module. To set up the Email module, you should click on it. A configuration window will appear.
2.b) Email module configuration
  1. First, choose the connection : select the IMAP connection that you configured (named My others IMAP connection)
  2. Select the /INBOX folder
  3. Select the Only unread mails criteria
  4. Click on No for Mark message(s) as read when fetched unless you want to mark messages as read.
  5. Don’t forget to click on OK at the bottom right of the window.
2.c) Dolibarr module configuration
Add the Dolibarr application by selecting the Create an event action that you created previously.
In the end, your screen should look like this :
Once you have your scenario is set up, you should fill the Dolibarr module fields with some Email fields, by following the steps below :
  1. Select the right connection
  2. Select the Email address with 1. Sender Email Address
  3. Select the Name with 1. Sender Email Name
  4. Select the Mail label with "1. Sender Email Name" : "1. Subject"
  5. Select the Received on field : 1.Date
  6. Choose the Type : 1
Make email parameters
  1. Click on OK
The scenario can now be executed. For this, click on the Run button at the bottom left of the screen.
Example of a module implementation to create a project task on Dolibarr
“Creation of a project task in Dolibarr once an issue is created on Github”
In this case, the Dolibarr instance receives information from Github. Github is a trigger that generates an action in Dolibarr, of creating a project task (Projects tab, Tasks/Activities section).
Here is the code that must be implemented on Make, to realize the scenario of creation of a project task in the module Projects of Dolibarr.
Required fields : There are two types of required fields, the ones which are required to create a valid task that can be accepted by Dolibarr and the fields that give information in the tasks list.
Fields corresponding to the Task list columns : task reference, task label, start date (type : date), end date (type : date), project reference, project status, expected workload, time consumed, consumption progress, actual progress declared (percentage), task progress
Mapping between API fields and their labels :
ref Task reference text K2304-0005
label Task label text
fk_project Project reference number 2
date_start Start date date 2023-03-12T18:25:43-05:00
date_end End date date 2023-03-12T18:25:43-05:00
date_creation Date of creation date
user_creation User that created the task text
planned_workload Estimated completion time (in seconds) number 8400
duration_effective Percentage of actual progress number 0
fk_user_creat ID of the user that created the event number 7
progress Progress of the project (in %) number between 0 and 100 50
Complete the following tabs as follows :
    "url": "{{connection.hostname}}/api/index.php/tasks",
    "method": "POST",
    "qs": {},
    "body": {
        "label": "{{parameters.taskName}}",
        "fk_project": "{{parameters.projectID}}",
        "date_start": "{{parameters.date_start)}}",
        "date_end": "{{parameters.date_end)}}",
        "user_creation": "{{parameters.creator)}}",
        "date_creation": "{{parameters.date_creation)}}",
        "fk_user_creat": "{{connection.userownerid}}",
        "ref": "{{parameters.taskref}}"
    "headers": {
    "response": {
Setting up the Github OAuth connection :
(Source : https://www.make.com/en/help/app/github?_ga=2.85846297.1242178067.1682759655-390117518.1678356777)
  1. Click the Add button next to the Connection field. Select the Connection type as OAuth.
  2. Optional: In the Connection name field, enter a name for the connection.
  3. Click on Save.
  4. a Github window should open. Confirm the access by clicking Authorize.
NB : You may have to reauthorize the connection to avoid some problems. On Make, in the left-side bar menu, select Connection. in the list of the connections, you may find (my Others IMAP connection). Click on Reauthorize.
        "name": "creator",
        "type": "text",
        "label": "Task created by:",
        "required": true
        "name": "taskName",
        "type": "text",
        "label": "Name of task",
        "required": true
        "name": "date_creation",
        "type": "date",
        "label": "Date of creation",
        "required": true
        "name": "date_start",
        "type": "date",
        "label": "Date of start",
        "required": true
        "name": "projectID",
        "type": "text",
        "label": "Project ID",
        "required": true
        "name": "date_end",
        "type": "date",
        "label": "Date of end",
        "required": true
        "name": "taskref",
        "type": "text",
        "label": "Reference of task",
        "required": true
d) Interface tab
        "name": "id",
        "type": "uinteger",
        "label": "User ID"
2nd scenario : Create a task in Dolibarr when a new issue is created on Github
2) Github scenario configuration
2.a) Github scenario initialization
  2. Select the Github module, that you can search it at the bottom of the drop-down list.
  3. Select the Watch issues trigger of this module.
To set up the Github module, you should click on it. A configuration window will appear.
2.b) Github module configuration
  1. First, you will need to associate the Github account from which you want to retrieve the issues created, through an OAuth connection.
  2. Then, you should choose if you want to watch all the repositories or only one repository of your linked Github account in the I want to watch field.
  3. Select the repository from which we want to launch the scenario on the repository field. All the repositories of the Github account will be displayed in a drop-down list.
  4. Choose the maximum number of returned issues : 10 for example
  5. Fill the watch field : select only new issues
  6. Then, select the filter : all issues(for example)
  7. Finally, select the state : only opened issues
Once your scenario is set up, you should fill the Dolibarr module fields with the available Github fields :
  1. Task created by : 1.Creator
  2. Name of task : 1.Title
  3. Date of creation : Date created
  4. Date of start : Date created
  5. Project ID : 1
  6. Date of end : Date updated
In the end, the window should look like :
Make github parameters
Click on OK.
3rd scenario : Create a new event in the Dolibarr calendar when creating one in Google Calendar
This scenario involves to automatically add a new event in the Dolibarr calendar when creating one in Google Calendar.
First, when creating your scenario on Make, you need to find the Google Calendar application in the list. Then select Watch Events among the several propositions. After, in the Connection section, add a connection with your Google account and accept the terms. In the Calendar section, choose your calendar account. Then, in the Watch Events section, select what interest you in particular. Finally, let the other sections by default.
Secondly, add the Dolibarr module at the right of the Google Calendar one, and fill its sections as follows :
  • Event name : 1. Summary
  • Start time : 1. Start
  • End time : 1. End
  • Description : 1. Description
  • Email adress : 1. Organizer: Email
You normally have the sections filled as follows :
Dolibarr module sections
Help for developpers
Viewing the code on VSCode
To view the code written on the Make website on VScode, it is possible to install the Make Apps SDK extension. More details can be found on the extension configuration page.
NB: The code viewed under VScode is stored in a local temporary repository on your computer, and it is synchronized with the code visible on Make.
On the other hand, it is only possible to export the code in .zip, which is annoying to put it on a Github repository for example.
Credits
This tutorial was produced by the AuTEAMation team as part of the design of interfacing prototypes between the Dolibarr ERP/CRM and several automation platforms for DoliCloud. This study was carried out as part of the PFA, a 2nd year group project at ENSEIRB-MATMECA.
