Draft:Discourse Implementation and Exploitation
Revision as of 12:47, 24 January 2025 by Jtraulle (talk | contribs) (→‎Upgrade the data container)
Apache2 config
Forums are available on entry URL: https://www.dolibarr.org/forum, https://www.dolibarr.fr/forum, https://www.dolibarr.de/forum but behind, it is discourse.
Enable proxy and proxy_http modules.
Add
   # To allow the rewrite on rss that is not a redirect from browser
   SSLProxyEngine on
   SSLProxyVerify none
   SSLProxyCheckPeerCN off
   SSLProxyCheckPeerExpire off
   # Redirection pour compatibilite avec ancien forum kunena
   RewriteRule ^/forum/user/(\d+)-(.*) /forum/u/$2/summary [L,R=permanent]
   RewriteRule ^/forumold/.*/(\d+)-(.*)$ /forum/t/$2 [L,R=permanent]
   # Redirection pour transfert apache - discourse
<Location "/forum">
    RequestHeader set "X-Forwarded-Proto" expr=%{REQUEST_SCHEME}
    RequestHeader set "X-Forwarded-SSL" expr=%{HTTPS}
    ProxyPreserveHost On
    ProxyPass "http://127.0.0.1:8800/forum" connectiontimeout=60 timeout=60
    ProxyPassReverse "http://127.0.0.1:8800/forum"
</Location>
The apache proxy redirect HTTP including /forum/ in URL to the port the docker nginx server run.
The Logs of the proxy are available into /home/dolibarr/logs/dolibarr_ssl_access_log file and are used by fail2ban rules.
Firewall
Les regles du firewall sont définies et activé par le script /home/dolibarr/tools/firewallvmprod1
TODO Utiliser ufw
Backup
Backup of discourse instance is done into directories /mnt/sdb1/backup/discourses
MySQL/MariaDB Databases
Docker
Installed following the Docker docs : https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-engine---community-1
Tests for dolibarr.de migration
  • Retrieve test VM backup
  • Update packages (apt)
  • Upgrade db to postgres12 (data container)
  • rebuild web_only container tu upgrade to same discourse version as prod
Upgrade the web container
From : https://meta.discourse.org/t/faster-rebuilds/40341/13
cd /var/discourse
sudo git pull
See https://meta.discourse.org/t/postgresql-12-update/151236#data-container-install
cd /var/discourse
sudo ./launcher stop web_only
sudo ./launcher stop data
# twice is not a typo but on purpose
sudo ./launcher rebuild data
Useful resources
