FAQ I Lost my password
You may have forget your MariaDB or MySQL database password, or, for an unknown reason, it does not works anymore. This is a solution to restore this.
This FAQ speak about a MySQL database administrator password problem and not about the lost of the password of a Dolibarr account used to work on Dolibarr.
With Microsoft Windows
If you lost the root password of MariaDB/MySql
- Connect to a Windows administrator account on your computer,
- Go on menu Windows:
Menu Start -> parameters -> Setup panel -> Administration tools -> Services.
- Find the service MySQL doliwampmysql into the list and stop it (we assume you installed DoliWamp. Name may differs if using a manuel installation of MySql).
- Launch the command line command by going to
Menu Start -> Execute -> cmd
- Type the following lines to restart MySQL in a particular mode.
CD C:\dolibarr\bin\mysql\mysql5.0.45\bin C:\dolibarr\bin\mysql\mysql5.0.45\bin\mysqld-nt --skip-grant-tables
- Launch another command line by going to
- Type in this new windows
CD C:\dolibarr\bin\mysql\mysql5.0.45\bin C:\dolibarr\bin\mysql\mysql5.0.45\bin\mysql -u root
- At the MySQL prompt, type
mysql> UPDATE mysql.user SET Password = PASSWORD('anewpassword') WHERE User = 'root';
mysql> FLUSH PRIVILEGES;
mysql> QUIT;
- Type
C:\dolibarr\bin\mysql\mysql5.0.45\bin\mysqladmin -u root -panewpassword shutdown
- Restart Windows.
You should now be able to access your MySQL database, you can now tell to Dolibarr to use the new password.
Change the user used by Dolibarr to connect to the database
- Go into
C:\dolibarr\www\dolibarr\htdocs\conf
- Edit file conf.php to change variable
$dolibarr_main_db_pass
with value of the new password.
- Save file and quit. It should be ok.
If Dolibarr use another MySQL user than root,
- Go in Windows menu
Menu Start - > execute -> CMD
cd C:\dolibarr\bin\mysql\mysql5.0.45\bin\
C:\dolibarr\bin\mysql\mysql5.0.45\bin\mysql -u root -ppassword
mysql> UPDATE mysql.user SET Password = PASSWORD('anothernewpassword') WHERE User = 'userusedbydolibarr';
mysql> QUIT;
- Go into
- edit file conf.php and search lines
$dolibarr_main_db_user="xxx";
$dolibarr_main_db_pass="yyy";
Replace xxx and yyy by real values.
Linux
If you lost the root password of Mysql or MariaB
- Connect to a terminal console with user roor.
- Stop Mysql:
/usr/sbin/mysql stop
- Type the following line to restart MySQL in a particular mode.
/usr/sbin --skip-grant-tables
- Launch another terminal console.
/usr/bin/mysql -u root
or on a more recent version
mysql> SET PASSWORD FOR 'root@localhost' = PASSWORD('anewpassword');
Then validate the change with
mysql> QUIT;
- Type
/usr/bin/mysqladmin -u root -panewpassword shutdown
- Restart your server or only mysql server.
- Go into
htdocs\conf
- Ru mysql with root user
/usr/bin/mysql -u root -ppassword
mysql> QUIT;
- Go into
htdocs\conf
