Module TwoFactorAuth
Revision as of 12:55, 9 January 2025 by Hregis (talk | contribs)
Module name TwoFactorAuth
Editor / Editeur Régis Houssin (iNodbox) - https://www.inodbox.com/
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/product.php?id=1288
Last update date / Date mise à jour fiche / Fecha última actualización 2025-01-9
With this module, You can add a Double Factor Authentication (2FA) in Dolibarr. This modules support the protocol TOTP and U2F (USB keys and fingerprint).
The module is compatible with 2FA OTP tools like Google Authenticator, Authy, ...
