Module Splash
Revision as of 11:11, 12 October 2024 by Eldy (talk | contribs)
Module name Splash
Editor / Editeur SplashSync - https://www.splashsync.com/
Dolibarr max version: See on Dolistore
Last update date / Date mise à jour fiche / Fecha última actualización 2024-10-12
Add, into Dolibarr ERP/CRM software, a module to allow to use the Splash synchronizing platform to synchronize data between Dolibarr and other software like Prestashop, Woocommerce, Odoo, ...
Direct link: https://www.dolistore.com/fr/modules/789-Connecteur-Splash-Sync.html
You must have a look at the SplashSync documentation. https://splashsync.gitlab.io/Dolibarr/
