Module Splash
| Module name | Splash |
| Editor / Editeur | SplashSync - https://www.splashsync.com/ |
Dolibarr max version: See on Dolistore |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2024-10-12 |
| Note / Nota |
Add, into Dolibarr ERP/CRM software, a module to allow to use the Splash synchronizing platform to synchronize data between Dolibarr and other software like Prestashop, Woocommerce, Odoo, ...
Direct link: https://www.dolistore.com/fr/modules/789-Connecteur-Splash-Sync.html
You must have a look at the SplashSync documentation.
