Draft:Discourse Implementation and Exploitation
Apache2 config
Forums are available on entry URL: https://www.dolibarr.org/forum, https://www.dolibarr.fr/forum, https://www.dolibarr.de/forum but behind, it is discourse.
Enable proxy and proxy_http modules.
Add
# To allow the rewrite on rss that is not a redirect from browser
SSLProxyEngine on
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerExpire off
# Redirection pour compatibilite avec ancien forum kunena
RewriteRule ^/forum/user/(\d+)-(.*) /forum/u/$2/summary [L,R=permanent]
RewriteRule ^/forumold/.*/(\d+)-(.*)$ /forum/t/$2 [L,R=permanent]
# Redirection pour transfert apache - discourse
<Location "/forum">
RequestHeader set "X-Forwarded-Proto" expr=%{REQUEST_SCHEME}
RequestHeader set "X-Forwarded-SSL" expr=%{HTTPS}
ProxyPreserveHost On
ProxyPass "http://127.0.0.1:8800/forum" connectiontimeout=60 timeout=60
ProxyPassReverse "http://127.0.0.1:8800/forum"
</Location>
The apache proxy redirect HTTP including /forum/ in URL to the port the docker nginx server run.
Firewall
Les regles du firewall sont définies et activé par le script /home/dolibarr/tools/firewallvmprod1
TODO Utiliser ufw
Backup
Backup of discourse instance is done into directories /mnt/sdb1/backup/discourses
MySQL/MariaDB Databases
Docker
Installed following the Docker docs : https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-engine---community-1
Tests for dolibarr.de migration
- Retrieve test VM backup
- Update packages (apt)
- Upgrade db to postgres12 (data container)
- rebuild web_only container tu upgrade to same discourse version as prod
Upgrade the web container
From : https://meta.discourse.org/t/faster-rebuilds/40341/13
cd /var/discourse
sudo git pull
Upgrade the data container
See https://meta.discourse.org/t/postgresql-12-update/151236#data-container-install
cd /var/discourse
sudo ./launcher stop web_only
sudo ./launcher stop data
sudo ./launcher rebuild data
