Module Stancer DoliCloud
Module name Stencer
Dolibarr min version: 20    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2024-09-4
Add into Dolibarr a Stencer online payment page (credit/debit cards). This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...).
Prerequisites
This module requires an instance of Dolibarr version 20 or +.
From the application
Manually
unzip modulefile.zip
Setup of Stencer Api
Generate the API keys required to make online payment with Stencer. They can be found on your Stencer account in the menu Developers
Setup of Dolibarr module
1) Create a bank account, called for example "My Stancer account" from menu "Home - Bank - New bank account", to record any payment done using Stencer.
2) Go on the setup page of Stencer module in Dolibarr and set the created bank account as the default bank account.
Setup test mode
To Setup the test mode, the only thing to do is fill "Stancer secret test API key" field in setup page
Setup live mode
1) Enable production mode in setup page
2) Fill "Stancer secret live API key" field in setup page
The only thing to do to use the module is to use any Dolibarr default link to make an online payment. All the links provided by Dolibarr to make online payment will support payment using Stencer.
Here is an example of customer payment page:*
Development and contributions
Troubleshooting
