Draft:Discourse Implementation and Exploitation
Revision as of 12:37, 4 September 2024 by Eldy (talk | contribs)
Apache2 config
Les forums sont accessibles depuis les url https://www.dolibarr.org/forum
Apache2 virtual hosts config dolibarr.fr.conf and dolibarr.org.conf has been copied from vmprod1 (Servername apache directive has just been modified to match names specified in #Addresses).
Enabling proxy and proxy_http modules.
Adding
   # To allow the rewrite on rss that is not a redirect from browser
   SSLProxyEngine on
   SSLProxyVerify none
   SSLProxyCheckPeerCN off
   SSLProxyCheckPeerExpire off
   # Redirection pour compatibilite avec ancien forum kunena
   RewriteRule ^/forum/user/(\d+)-(.*) /forum/u/$2/summary [L,R=permanent]
   RewriteRule ^/forumold/.*/(\d+)-(.*)$ /forum/t/$2 [L,R=permanent]
   # Redirection pour transfert apache - discourse
<Location "/forum">
#    Deny from all
#    Allow from 37.170.87.101
#    RequestHeader set X-Forwarded-Port "443"
#    RequestHeader set X-Forwarded-Proto "https"
    RequestHeader set "X-Forwarded-Proto" expr=%{REQUEST_SCHEME}
    RequestHeader set "X-Forwarded-SSL" expr=%{HTTPS}
    ProxyPreserveHost On
    ProxyPass "http://127.0.0.1:8800/forum" connectiontimeout=60 timeout=60
    ProxyPassReverse "http://127.0.0.1:8800/forum"
</Location>
Firewall
Les regles du firewall sont définies et activé par lescript
/home/dolibarr/tools/firewallvmprod1
TODO Utilisé ufw
Files
Files from /home/dolibarr/dolibarr.fr and /home/dolibarr/dolibarr.org has been copied to the same location on the test VM (however /home/dolibarr/dolibarr.org/httpdocs/files/stable has not been replicated on the test VM due to the weight/size of all packages).
MySQL/MariaDB Databases
Docker
Installed following the Docker docs : https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-engine---community-1
Tests for dolibarr.de migration
  • Retrieve test VM backup
  • Update packages (apt)
  • Upgrade db to postgres12 (data container)
  • rebuild web_only container tu upgrade to same discourse version as prod
Upgrade the web container
From : https://meta.discourse.org/t/faster-rebuilds/40341/13
cd /var/discourse
sudo git pull
Upgrade the data container
See https://meta.discourse.org/t/postgresql-12-update/151236#data-container-install
cd /var/discourse
sudo ./launcher stop web_only
sudo ./launcher stop data
sudo ./launcher rebuild data
Useful resources
