Module Interventions
Revision as of 12:51, 19 August 2024 by W1W1M (talk | contribs) (Clarified difference between life cycle and signature status)
Interventions
Numero/ID of module 70
Developer doc. of module Module Interventions (developer)
Interventions are a form for service / maintenance orders.
Usage / Life cycle
Default setup
When the module is enabled, it is possible to create intervention files.
When an intervention is validated or closed, it is possible to add a signature on it.
The workflow of an intervention is the following (The number between parenthesis is the technical code of the status)
Draft (0) -------->  Validated (1) ------> Closed - Done (3)
       \------> Convert into a recurring intervention
With option FICHINTER_CLASSIFY_BILLED
If the hidden option FICHINTER_CLASSIFY_BILLED is defined, a step Billed is introduced.
Draft (0) ----->  Validated (1) ----> Billed (2) ----> Closed - Done (3)
Warning, this status/option will be removed. It must be replaced with a property "billed" that can be defined whatever is status "Validated" or "Done".
Signature status (Dolibarr v21 alpha)
Native signature statuses are available with Dolibarr v21 (currently in alpha testing) :
Status label Status code
Not signed 0
Signed internally 1
Signed by third party 2
Signed by third party online 3
Signed by all parties 9
Signature status can be set once an intervention is validated. They are independent of life cycle statuses. Default signature status is "Not signed".
Native online signature by a public user (third party) will automatically set the signed status to "Signed by third party".
Signature status makes use of FICHINTER_MODIFY action trigger with added context information, for automatic events and email notifications.
