Module Interventions
Interventions | |
Numero/ID of module | 70 |
Developer doc. of module | Module Interventions (developer) |
Interventions are a form for service / maintenance orders.
Usage / Life cycle
Default setup
When the module is enabled, it is possible to create intervention files.
When an intervention is validated or closed, it is possible to add a signature on it.
The workflow of an intervention is the following (The number between parenthesis is the technical code of the status)
Draft (0) --------> Validated (1) ------> Closed - Done (3) \ / \ / \----------<--------/ \----------<-------/ \ \------> Convert into a recurring intervention
With option FICHINTER_CLASSIFY_BILLED
If the hidden option FICHINTER_CLASSIFY_BILLED is defined, a step Billed is introduced.
Draft (0) -----> Validated (1) ----> Billed (2) ----> Closed - Done (3) \ / \----------<------/
Warning, this status/option will be removed. It must be replaced with a property "billed" that can be defined whatever is status "Validated" or "Done".
Signature status (Dolibarr v21 alpha)
Native signature statuses are available with Dolibarr v21 (currently in alpha testing) :
Status label | Status code |
Not signed | 0 |
Signed internally | 1 |
Signed by third party | 2 |
Signed by third party online | 3 |
Signed by all parties | 9 |
Signature status can be set once an intervention is validated. Default signature status is "Not signed".
Native online signature by a public user (third party) will automatically set the signed status to "Signed by third party".
Signature status makes use of FICHINTER_MODIFY
action trigger with added context information, for automatic events and email notifications.
