Module Interventions
Interventions
Numero/ID of module 70
Developer doc. of module Module Interventions (developer)
Interventions are a form for service / maintenance orders.
Usage / Life cycle
Default setup
When the module is enabled, it is possible to create intervention files.
When an intervention is validated or closed, it is possible to add a signature on it.
The workflow of an intervention is the following (The number between parenthesis is the technical code of the status)
Draft (0) -------->  Validated (1) ------> Closed - Done (3)
       \------> Convert into a recurring intervention
With option FICHINTER_CLASSIFY_BILLED
If the hidden option FICHINTER_CLASSIFY_BILLED is defined, a step Billed is introduced.
Draft (0) ----->  Validated (1) ----> Billed (2) ----> Closed - Done (3)
Warning, this status/option will be removed. It must be replaced with a property "billed" that can be defined whatever is status "Validated" or "Done".
