Module Interventions
Interventions | |
Numero/ID of module | 70 |
Developer doc. of module | Module Interventions (developer) |
Interventions are a form for service / maintenance orders.
Usage / Life cycle
Default setup
When the module is enabled, it is possible to create intervention files.
The workflow of an intervention is the following (The number between parenthesis is the technical code of the status)
Draft (0) --------> Validated (1) ------> Closed - Done (3) \ / \ / \----------<--------/ \----------<-------/ \ \------> Convert into a recurring intervention
With option FICHINTER_CLASSIFY_BILLED
If the hidden option FICHINTER_CLASSIFY_BILLED is defined, a step Billed is introduced.
Draft (0) -----> Validated (1) ----> Billed (2) ----> Closed - Done (3) \ / \----------<------/
Warning, this status/option will be removed. It must be replaced with a property "billed" that can be defined whatever is status "Validated" or "Done".
