Module Notification
Revision as of 13:53, 13 August 2024 by Eldy (talk | contribs)
Notification
Numero/ID of module 600
Developer doc. of module Module Notification (developer)
The notification module is used to send notifications (by emails) when some Dolibarr events occurs.
