Table llx propaldet
Revision as of 12:52, 25 July 2024 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains details of customer proposals. This table is linked to Table llx_propal
Fr verysmall.png Contient les détails des propositions commerciales, cette table est liée avec la Table llx_propal
Es verysmall.png Contiene los detalles de los presupuestos a clientes, esta tabla esta vinculada con Table llx_propal
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_propal int(11) YES NULL ID of propal (llx_propal->rowid)
fk_product int(11) YES NULL ID of product (llx_product->rowid)
label varchar(255) YES NULL
description text YES NULL product or service description
fk_remise_except int(11) YES NULL ID of discount (llx_societe_remise_except->rowid)
tva_tx double(6,3) YES 0.000 VAT taxes
qty real YES NULL Quantity of product or service
remise_percent real YES 0 discount percentage
remise real YES 0 discount amount (obsolete)
price real YES NULL final price (obsolete)
subprice double(24,8) YES 0.00000000 price before discount
total_ht double(24,8) YES NULL total excluding taxes
total_tva double(24,8) YES NULL total tax
total_localtax1 double(24,8) YES NULL total local tax 1
total_localtax2 double(24,8) YES NULL total local tax 2
total_ttc double(24,8) YES NULL Total including discount and taxes (vat + localtax1 + localtax2)
product_type int(11) YES 0 type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
info_bits integer 0 TVA NPR or NOT
pa_ht double(24,8) YES 0.00000000 purchase price HT
marge_tx double(6,3) YES 0.000 margin (margin on purchase price)
marque_tx double(6,3) YES 0.000 mark rate (margin on selling price)
special_code integer YES 0 0=default, 1=seems no more used (or may be used to set line as transport/shipping fee), 2=used by WEEE module to define line as a WEEE line, 3=option line (price must not included in total), 4=Sent for cooking (POS modules for restaurant), Module ID (>= 5)=value for a custom need. Value is an additional information and has no effect, except value 3 that means "do not take into account amount, it is an option" (so price must not be included in total, qty in this case should be also 0).
rang integer YES 0 Position of line. Lower value are line top, higher value are bottom.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
