Table llx commande fournisseurdet
Revision as of 11:18, 25 July 2024 by Eldy (talk | contribs)
Content/Contenu/Contenido
En verysmall.png Contains details of providers orders. This table is linked to Table llx_commande_fournisseur
Fr verysmall.png Contient les détails des commandes fournisseurs, cette table est liée avec la Table llx_commande_fournisseur
Es verysmall.png Contiene los detalles de los pedidos a proveedores, esta tabla esta vinculada con Table llx_commande_fournisseur
Structure
Tables
rowid int(11) NO PRI auto_increment technical index
fk_commande int(11) NO ID of order (llx commande->rowid)
fk_product int(11) YES NULL ID of product (llx_product->rowid)
ref varchar(50) YES NULL supplier ref. of product
label varchar(255) YES NULL label of product
description text YES NULL product description
tva_tx double(6,3) YES 0.000 VAT taxes
qty real YES NULL Quantity of product
remise_percent real YES 0 discount percentage
remise real YES 0 discount amount
subprice double(24,8) YES 0.00000000 unit price before
total_ht double(24,8) YES NULL total excluding taxes
total_tva double(24,8) YES NULL total tax
total_localtax1 double(24,8) YES NULL total local tax 1
total_localtax2 double(24,8) YES NULL total local tax 2
total_ttc double(24,8) YES NULL Total including discount and taxes (vat + localtax1 + localtax2)
product_type int(11) YES 0 type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
info_bits integer 0 TVA NPR or NOT
Keys
Key Type Fields
PRIMARY PRIMARY rowid
