Table llx commandedet
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contient les détails des commandes clients, cette table est liée avec la Table llx_commande
Contains details of customer orders. This table is linked to Table llx_commande
Contiene los detalles de los pedidos de clientes, esta tabla esta vinculada con Table llx_commande
Structure
Table
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | NO | PRI | auto_increment | technical index | |
fk_commande | int(11) | NO | MUL | ID of order (llx commande->rowid) | ||
fk_parent_line | int(11) | YES | NULL | Since ? | ||
fk_product | int(11) | YES | NULL | ID of product (llx_product->rowid) | ||
description | text | YES | NULL | product or service description | ||
tva_tx | double(6,3) | YES | NULL | VAT taxes | ||
qty | real | YES | NULL | Quantity of product or service | ||
remise_percent | real | YES | 0 | discount percentage | ||
remise | real | YES | 0 | discount amount | ||
fk_remise_except | int(11) | YES | NULL | ID of discount (llx_societe_remise_except->rowid) | ||
price | real | YES | NULL | final price | ||
subprice | double(24,8) | YES | 0.00000000 | price before discount | ||
total_ht | double(24,8) | YES | NULL | total excluding taxes | ||
total_tva | double(24,8) | YES | NULL | total tax | ||
total_localtax1 | double(24,8) | YES | NULL | total local tax 1 | ||
total_localtax2 | double(24,8) | YES | NULL | total local tax 2 | ||
total_ttc | double(24,8) | YES | NULL | Total including discount and taxes (vat + localtax1 + localtax2) | ||
product_type | int(11) | YES | 0 | type of prodcut | ||
date_start | datetime | YES | NULL | start date if service | ||
date_end | datetime | YES | NULL | end date if service | ||
info_bits | int(11) | YES | 0 | TVA NPR or not | ||
marge_tx | double(6,3) | YES | 0.000 | margin (margin on purchase price) | ||
marque_tx | double(6,3) | YES | 0.000 | mark rate (margin on selling price) | ||
special_code | integer | YES | 0 | 0=default, 1=seems no more used (or may be used to set line as transport/shipping fee), 2=used by WEEE module to define line as a WEEE line, 3=option line (price must not included in total), 4=Sent for cooking (POS modules for restaurant), Module ID (>= 5)=value for a custom need. Value is an additional information and has no effect, except value 3 that means "do not take into account amount, it is an option" (so price must not be included in total, qty in this case should be also 0). | ||
rang | int(11) | YES | 0 | order view | ||
import_key | varchar(14) | YES | NULL | Code used to save the import id. See page Field Import key. |
Keys
Key | Type | Fields |
PRIMARY | PRIMARY | rowid |
idx_commandedet_fk_commande | MULTIPLE | fk_commande |
