Table llx element time
Revision as of 12:05, 18 June 2024 by Eldy (talk | contribs) (Eldy moved page Table llx projet task time to Table llx element time)
Content/Contenu/Contenido
En verysmall.png Contains the time spend by actors of a project task at a given time.
Fr verysmall.png Contient le temps passé par acteurs et par date sur une tâche de projet.
Es verysmall.png Contiene los tiempos invertidos por los actores relacionados a un proyecto.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_task int(11) NO ID of task (llx_projet_task->rowid)
task_date date YES NULL date time when the actor has spend time on the task (started to work)
task_duration double YES NULL time spend, duration from the date time above
fk_user int(11) YES NULL ID of user or contact having spend time (Table llx element contact->fk_socpeople)
note text YES NULL commentary notes
Keys
Key Type Fields
PRIMARY PRIMARY rowid
