Module AI (Artificial Intelligence)
| AI (Artificial Intelligence) functionalities | |
| Numero/ID of module | 4560 |
| Developer doc. of module | Module AI(developer) |
With this module, you can generate a wide range of content with ease. Craft compelling text, produce stunning images, create natural-sounding audio, translate languages effortlessly, and explore endless creative possibilities.
This user-friendly module integrates seamlessly with Dolibarr, empowering you to save time, enhance communication, and reach a global audience.
Note that activating this module will automatically activate the Module Third Parties.
More configuration
To set up the service, simply select the AI provider (such as ChatGPT, Grok, or another) and specify the API key, which you can find in a section of your account for that service. Additionally, the module allows you to configure the prompt for each specific instruction.
You can edit the prompt by clicking on the button edit, also you can delete it.
For example, if you're using a text generation feature, you can set a pre-prompt that contains the required instruction and a post-prompt that adds further details. This approach can make it much easier for your AI to generate highly specific output
Generate with the dedicated prompt
By activating module AI, a button will be shown to display the prompt where you can enter your instruction.
Note : For the time being, this function is only available when sending emails.
Life cycle
