Module AI (Artificial Intelligence)
Revision as of 16:01, 10 May 2024 by Abdel (talk | contribs) (Created page with "<!--BEGIN origin interlang links--><!--You can edit this section but do NOT remove these comments Links below will be automatically replicated on translated pages by Poly...")
AI (Artificial Intelligence) functionalities
Numero/ID of module 80
Developer doc. of module Module AI(developer)
With this module, you can generate a wide range of content with ease. Craft compelling text, produce stunning images, create natural-sounding audio, translate languages effortlessly, and explore endless creative possibilities.
This user-friendly module integrates seamlessly with Dolibarr, empowering you to save time, enhance communication, and reach a global audience.
If a cog icon appears Cog circle.svg on module thumb or at end of the line of the module, click on it to access the setup page specific to the module. Note that activating this module will automatically activate the Module Third Parties.
