Subscription amount Dolibarr Foundation
Revision as of 10:03, 3 April 2024 by Grandoc (talk | contribs) (Undo revision 60018 by Grandoc (talk))
Back to Dolibarr
foundation home page
You will find here the minimum amount for subscription to the Dolibarr foundation, depending on your status.
Natural persons
This is when you subscribe for yourself.
Minimum subscription fee for natural persons is: 20 € minimum.
Moral persons
If your subscription is for your company, association or university the fee depends on the institution characteristics.
Companies
Subscription fee depends on the turnover:
  • Turnover lower than 100 000 € : subscription is 50 €
  • Turnover from 100 000 to 200 000 € : subscription is 100 €
  • Turnover from 200 000 to 500 000 € : subscription is 200 €
  • Turnover from 500 000 to 1.5 millions € : subscription is 300 €
  • Turnover from 1.5 to 3 millions € : subscription is 600 €
  • Turnover from 3 to 5 millions € : subscription is 1 000 €
  • Turnover higher than 5 millions € : subscription is 2 000 €
Associations
Subscription fee depends on the budget:
  • Budget lower than 100 000 € : subscription is 50 €
  • Budget from 100 000 € to 200 000 € : subscription is 100 €
  • Budget from 200 000 € to 500 000 € : subscription is 200 €
  • Budget from 500 000 € to 1.5 millions € : subscription is 300 €
  • Budget from 1.5 to 3 millions € : subscription is 600 €
  • Budget from 3 to 5 millions € : subscription is 1 000 €
  • Budget higher than 5 millions € : subscription is 2 000 €
Other
For towns, universities and any other institutions subscription is 100€.
